![]() Join Date: Jun 2006
Yellow STI injectors DO work
Well, I put the yellow STI side feed injectors in my car, and it started right up and idled "okay" I could tell it was running a little rich, but it wasn't going to stall, I have yet to install the Z32 MAF or the ECU (both I have, doing that tomorrow, it got too dark). Just letting everyone know there is a nice low cost alternative out there. Hell, you can get them remained from autoparts giant for about $190 for a set of four.
Everything I have read tells me they are 550 high impedance. If anyone has any information that does not correspond to this please let me know. My ECU is chipped so I can tune it for the proper injector size. |
#8 | |
Actually its the other way around. If the injectors are LOW impedance and the ECU requires HIGH impedance, then yes you would require to use a resister to change the impendance of the injectors from LOW to HIGH, otherwise you will burn out the injector driver in the ECU (BAD!!!) because it would draw too much current, lower ohms equals higher current draw, like speakers (I believe). However, from what I have heard if the ECU uses low impedance, and you put in high,, you don't need to do anything. However the ECU uses HIGH imp and the injectors are HIGH imp (from what I've heard). So you don't need to do anything |
Yes I had to change the plugs, that was pretty easy, I made quick disconnect pigtails, so I can change out the Sr20's 370's or the STI's 550's
BTW,, they don't have to be a STI plugs,, Legacy plugs will work too (that's what I used) |
you just need the clips/plugs, whatever you want to call it.
and you splice it with STI clips. hopefully you got it with the injectors.. if not, more than likely, autoparts store will have em. there are two wires, and only two wires. its really self explanatory after the drop-in. ![]() |
Yeah,, that's pretty much them,, You can go to Autoparts Giant and pick up some remans for $165, or new Pythons for $190. Either way, its DIRT cheap for a nice injector upgrade. Look up part# 842-18132
#23 |
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
I've been told they're 520cc, not 550, by a guy who has done quite a bit of Nissan tuning with them. Anything to that?
E36 M3 - new project 1990 240SR - screamed down the road |
#25 | |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
I do to bad you could send them with the turbo you already sent. |
#26 |
I guess you could up the fuel pressure a few pounds and make them flow 550 without a prob,, I'm guessing running around 49psi instead off 43.6 should get you at 550cc.
#30 |
![]() Join Date: Feb 2005
if anyone needs any, i work at a dealership and can get them AT cost!
"So here I am, right back at it again, just like I've always been" ![]() |
