Old 11-14-2002, 06:03 PM   #1
Jim96SC2
Jim96SC2 is an unknown quantity at this point
Send a message via AIM to Jim96SC2
I need to get the KA out of my engine bay to make room for the SR. I have everything save the throttle lines, and the wiring harness unplugged and out of the way. The tranny is giving me a slight headache. Whats the best way to pull it? Those top bolts are a pain to get at. Best way I can figure right now is take it off the crossmember, lift it with a jack to push the back of the engines forwards and get at the bolts. Any other suggestion?
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter.
Jim96SC2 is offline   Reply With Quote
Old 11-14-2002, 10:50 PM   #2
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
When I pulled mine, I pulled it with the tranny still attached to the engine as one unit.
If you remove everything in front of the engine, there should be enough room.
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
Old 11-15-2002, 12:24 AM   #3
gschroeder78
gschroeder78 is an unknown quantity at this point
Send a message via Yahoo to gschroeder78
I haven't pulled the KA yet but when I pulled my Z32 engine I got to the top bolts by jacking up the crank pully on the engine. It tilted it back far enough to get the bolts. You need 3' worth of extension to do it. You can pull it with the tranny still attached but to me it seems harder. I haven't tried it but it seems harder.
1989 240SX Coupe
-Eibach Prokit Springs
-KYB AGX Struts
-Apex-i N1 Dual Exhaust
Westminster, CO
gschroeder78 is offline   Reply With Quote
Old 11-15-2002, 06:46 AM   #4
bbp
bbp's Avatar
bbp is an unknown quantity at this point
Here is the easiest way to remove a motor from a 240sx.
Put car on 4 stands (not the cheap-o foot high stands...get the nice big ones that raise the car about 2 feet or so).  Disconnect all hoses, wiring, exhaust pipe, radiator, intake pipe.  Disconnect the steering tie rods at the knuckle and the lower ball joint on the control arm.  Remove TC rods.  Remove Shifer inside the car.
Connect engine lift to the top of the motor.  Remove 4 bolts on the lower crossmember and 4 bolts on the tranny crossmember.  Lower engine onto a creeper or similar rolling device.  connect lift to the front of the body to allow the engine to slide out from under.
I'm sure I am missing a few details but you get the picture.
Installation is reversed order.  I can remove my drive train in about 2-3 hours by myself and about 2 hours with a helper.  It can be installed in about 4 hours by one person.
bbp is offline   Reply With Quote
Old 11-15-2002, 10:32 AM   #5
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
...bottom line, to save time and to get the job done. With the car in the air, use a 3', 1/2" extension and use that to reach the bolts on the top of the 'mission bell housing. I recently pulled mine and prior to that, working on clutches and 'missions, that's the easiest way to get'em out and off.
You may also need to make use of a universal bit too but that is all you'll need. 1) 1/2" rachet, 2) 3', 1/2" extension, 3) -maybe- 1, 1/2" universal bit...
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
