Old 11-02-2007, 02:51 AM   #1
drft911
drft911's Avatar
drft911 has made poor choicesdrft911 has made poor choicesdrft911 has made poor choicesdrft911 has made poor choicesdrft911 has made poor choicesdrft911 has made poor choices
sr20det timing
what can cause my timing to be way off the mark?i checked the timing and it was beyond 20deg the marks werent close to the needle....i think it can be a bad knock sensor...when i try to adjust it to 15deg i have to move the cas all the way counterclockwise and when i do that the ehxaust smell like gas....
drft911 is offline   Reply With Quote
Old 11-02-2007, 02:56 AM   #2
HellonFire
HellonFire's Avatar
HellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud ofHellonFire has much to be proud of
Send a message via AIM to HellonFire
Your mechanical timing is off.
Tyler
HellonFire is offline   Reply With Quote
Old 11-02-2007, 05:27 PM   #3
drft911
drft911's Avatar
you mean cas? is bad?or what?
Old 11-02-2007, 11:27 PM   #4
drft911
drft911's Avatar
ok i checked the timing again and this time from the entire #1 coil pack harness and was at 15deg.....but i still dont get why it was way off the i check it from the black wire in back of the valve cover?someone?
Old 11-02-2007, 11:42 PM   #5
SamuraiSam
SamuraiSam is an unknown quantity at this point
Sometimes when you use the wire at the back of the motor, if you have the pickup flipped the wrong way, you will get a wildly inaccurate timing reading. Try flipping the pickup around the wire and see if the reading goes crazy again. Whichever value is lower is the correct one (IIRC)
Amateur snowboarder, music buff, bedroom documentarian, closet Nissan fanboy, apprentice mechanic, certified Honda nut, EFI 101 attendee/graduate
"You are going to work all your life to become an overnight success." -Warren Miller
SamuraiSam is offline   Reply With Quote
Old 11-03-2007, 11:49 AM   #6
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
The only way I got an accurate reading for timing was to use an old spark plug wire. That is the best way to do it. If you don't you can get erroneous readings.
makulit054 is offline   Reply With Quote
Old 11-03-2007, 08:58 PM   #7
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
gj on setting ignition base timing =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
