black top with red top ecu
i had my motor for 2 years runs great but iits a black top s13 and i have been running a red to #63 ecu is that bad could it harm any thing i know theres like almost no difference in the motors but why do they come with different ecu # .....any in fo would be great thanks also what # is the black top...thanks
![]() Join Date: Jan 2007
if it ain't broke don't fix it. i believe the only difference may be the o2 sensor pins. do an ecu pinout comparison.
Dave
![]() Join Date: Dec 2006
Black Top ECU has a few pins moved around
#7 | |
Redtop AT -63 Blacktop MT- E5
92 FastBack - Project 98 SE - Daily Driver |
Couple of pin are @ different location for 62 (S13 redtop) and E5(S13 blacktop). If you read the map of these 2 ecu 62(50f00) and E5(50f05), there is a major difference in fuel map, even the rev limit is different.
#11 | |
![]() Join Date: Apr 2007
63 is s13 silvia/180sx auto ecu. I know that for a fact. So, no you will not run into any issues, you are fine. You prolly dont have the speed cut at 118 right? The only s13 ecu that is not compatible without repining is the j4 from the typex because it came with more electronic features that are pinned in there. Anyone back me on this one |
i do have the speed cut i need to look i might have a #62 but I do have a black top the head has the fins in the front, is the fuel maps the same for the black and red top ecu.
I would assume since they both are factory rated for the same power. If you do have a fuel cut, then I beleive that you probually have the # 62.
E5 62 and 63 all work with the same harness. j4 does not. I learned that one the hard way. |
#14 | |
Man w/ CTSV & a Car Seat
But yah E5 and 63 ECUs are interchangeable. The only difference between an early blacktop and redtop S13 engines are the ECU code, o2 sensor size (but you can still interchange those, just use what elbow size your using) and the blacktops have better cooling (head fins). Im saying this since ive had personal experience on this, Ive run both 63 and E5 ECU and swapped engines around. |
#15 |
![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
so confusing this thread.
http://squarespokes.com/ |
#17 |
![]() Join Date: Oct 2006
the one with the pins moved around is the J4/5 not the E5/6 the 62/63 is the same as the E5/6.
The small and big o2 sensors output the same - so its whatever fits ur car. I've swapped those ecus back and forth and tuned both with daughterboards... You'll have no problems. Now i dont run either anymore - just use the programmable narrow output off the innovate.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
