Old 11-07-2007, 04:28 PM   #1
eastcoastS14
eastcoastS14's Avatar
whats wrong with my car?
Ok so lately my engine has started making a lot of noise....specifically it sounds like there is an egg timer under my hood. It has been doing this since I got my headgasket replaced which had me thinking it was the top timing chain tensioner maybe? Also my idle bounces around A LOT usually after the engines been under load and I stop at a light or something, strangely it gets even worse when I cut the wheel all the way. I cut the wheel to park the other day and the car stalled which was a first....I was thinking maybe the IACV but i dont understand why it stalled when i cut the wheel. as the idle bounces usually between 500-1k rpms the lights dim in and out so alternator maybe? anyway heres videos of my bouncing idle if that helps
eastcoastS14 is offline   Reply With Quote
Old 11-07-2007, 04:57 PM   #2
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
i believe that is called 'hunting' check the ef & ec section of your year's factory service manual.
WheelsDirty
Old 11-07-2007, 05:02 PM   #3
johngriff
johngriff's Avatar
TPS
BASE TIMING
AIR IN COOLANT SYSTEM (explains the noise "ticking" from under the hood, also known as detonation).
[email protected]
