Old 11-08-2007, 12:42 PM   #1
RuRoUnI_S14
RuRoUnI_S14's Avatar
RuRoUnI_S14 is on the path to ruinRuRoUnI_S14 is on the path to ruin
Ilding pretty high with some other issues.....
My car currently idles pretty high and I don't know why. Even after driving around for about 30 minutes to an hour, at a stop it idles from 1500 - 2000 rpms. I have a Sr20DET, FMIC, HKS BOV, Down pipe, test pipe, apexi exhaust, GReddy Spec II EBC set at 7.5 lbs. of boost, ACT lightened flywheel, Stage III Clutch, and I have not tuned the car yet. so I'm just wondering may that be it. Does it hurt the car at all? Or should I just be ok?
RuRoUnI_S14 is offline   Reply With Quote
Old 11-08-2007, 05:59 PM   #2
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
check your IACV or idle adjustment screw. an increase in air entering the motor is prolly causing the higher rev.
it wont hurt anything
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 11-08-2007, 06:23 PM   #3
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
check ur belts ,and the maf, try reseting the ecu..
2.7L
240trooper is offline   Reply With Quote
Old 11-08-2007, 06:25 PM   #4
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Where do you live?? Your thermo might be stuck open and making your engine run cold. Do you have a temp gauge and wideband?
undesiredshoe is offline   Reply With Quote
Old 11-08-2007, 07:17 PM   #5
RuRoUnI_S14
I live in philadelphia, I don't think my thermostat is stuck open. I don't have a wideband yet and my temp guage is right at the middle. I will try The valve adjustment.
Old 11-08-2007, 08:44 PM   #6
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
check your throttle cable and see if the throttle plate is fully closed when the pedal is released all the way... if thats not it clean your idle valve
Zzzz
bongnak is offline   Reply With Quote
Old 11-08-2007, 08:50 PM   #7
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
all of the above from bongnak, and if i can remember, its been a few years since i have had a idle valve on my car, but when they go bad the car will idle right around that area. Take it of and clean it, then run the tests that they dictate in the FSM, i believe you might even be able to unplug it and plug it back in to here if its actually moving the valve open/shut. I went through allot of bad valves and eventually just made a block off plate and ran idle adjustment off my throttle stop, i know its a little ghetto, but its worked for 2+ years.
Jon
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
