tranny grinds w/ new clutch master?
Hi! my tranny died last month, after waiting for a month for the parts. I got the part last week, and starting to put everything together. the initial problem was the clutch padel dropped to the floor and not coming up. I found that the pivot bolt was snap in half, after replacing the bolt, it still won't work, so i decided to take the tranny out and see watz going on there, and might as well do a clutch and fidenza flywheel job, after taking the tranny out. I didnt see anything wrong, so I decided to put everything together and might as well do the dampener bypass along w/ new clutch master and slave replacement. After all these has been done, my car finally moves again, but then I have trouble trying to get into 1st gear, and 2nd, 3rd, 4th........pretty much all gear grinds as I drive. It used to be perfect b4 it died. Any1 seen this before? is it just that parts needs run-in??
here is parts I have replaced: Exedy OE replacement clutch kit Fidenza 11lb flywheel beck & arnley Clutch master cylinder beck & arnley clutch slave cylinder PDM clutch dampener bypass line little pivot bolt flush the clutch fluid all tranny fluid and diff fluid flushed w/ motul gear 75w90 sync oil any suggestions what I did wrong??? Last edited by s13_newbie; 11-08-2007 at 10:22 PM.. Reason: missing info |
![]() Join Date: May 2007
is it aligned correctly?
<------ Grumpy Old Asshole MY REVIEW THREAD: Ltdnismoracer4=DOOK http://www.zilvia.net/f/showthread.p...ltdnismoracer4 |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
DEFINITELY bleed the clutch. I am 90% sure that is your problem. If the clutch wasn't aligned correctly then you wouldn't be able to get the trans in.
I second that! Happened to me twice! So i was driving with a cluth pedal that wasnt stiff at all! I bled the clutch and wala! Feels like a brand new one!
