Old 11-08-2007, 10:20 PM   #1
s13_newbie
s13_newbie is making his/her stupidity well-knowns13_newbie is making his/her stupidity well-knowns13_newbie is making his/her stupidity well-knowns13_newbie is making his/her stupidity well-known
tranny grinds w/ new clutch master?
Hi! my tranny died last month, after waiting for a month for the parts. I got the part last week, and starting to put everything together. the initial problem was the clutch padel dropped to the floor and not coming up. I found that the pivot bolt was snap in half, after replacing the bolt, it still won't work, so i decided to take the tranny out and see watz going on there, and might as well do a clutch and fidenza flywheel job, after taking the tranny out. I didnt see anything wrong, so I decided to put everything together and might as well do the dampener bypass along w/ new clutch master and slave replacement. After all these has been done, my car finally moves again, but then I have trouble trying to get into 1st gear, and 2nd, 3rd, 4th........pretty much all gear grinds as I drive. It used to be perfect b4 it died. Any1 seen this before? is it just that parts needs run-in??
here is parts I have replaced:
Exedy OE replacement clutch kit
Fidenza 11lb flywheel
beck & arnley Clutch master cylinder
beck & arnley clutch slave cylinder
PDM clutch dampener bypass line
little pivot bolt
flush the clutch fluid
all tranny fluid and diff fluid flushed w/ motul gear 75w90 sync oil
any suggestions what I did wrong???
s13_newbie is offline   Reply With Quote
Old 11-08-2007, 10:22 PM   #2
DOOK
DOOK's Avatar
is it aligned correctly?
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 11-08-2007, 10:24 PM   #3
s13_newbie
yes. I make sure I aligned correctly. I have triple check to make sure, coz I know if I didn't aligned correctly, more stuff will be damaged.......
Old 11-08-2007, 10:26 PM   #4
MadMaverick
MadMaverick's Avatar
MadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really nice
did you try bleeding the clutch again?
MadMaverick is offline   Reply With Quote
Old 11-08-2007, 10:28 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
DEFINITELY bleed the clutch. I am 90% sure that is your problem. If the clutch wasn't aligned correctly then you wouldn't be able to get the trans in.
Old 11-08-2007, 10:30 PM   #6
MadMaverick
also, did you bench bleed the master before installing it?
Old 11-08-2007, 10:32 PM   #7
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
you can try adjusting the clutch pedal if bleeding it doesnt help... all you need is a 12mm wrench
louisdaboois is offline   Reply With Quote
Old 11-08-2007, 10:34 PM   #8
Borund
Borund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymoreBorund is not welcome here anymore
Send a message via AIM to Borund
I second that! Happened to me twice! So i was driving with a cluth pedal that wasnt stiff at all! I bled the clutch and wala! Feels like a brand new one!
Borund is offline   Reply With Quote
Old 11-09-2007, 01:16 AM   #9
s13_newbie
i will try that them tomorrow................
Thanks for all your input!
Old 11-09-2007, 01:20 AM   #10
!Zar!
!Zar!'s Avatar
This sounds like it could be the reason. Assuming you know how to bleed a clutch...
