Old 11-09-2007, 01:45 PM   #1
steve_o1989
steve_o1989's Avatar
steve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond repute
Ka24e Idle Problems
First off, I did a quick search and couldn't find what I was looking for.
Well, my car is a 1990 240sx with a ka24e with about 30,000 on a rebuild. I had this same idling issue with my old ka, but not as bad. The engine doesn't do this all the time, but most of the time it idles high. Usually around 1400rpm, but it will occasionally jump up to 1900rpm. Sometimes, not all the time, if I have my heat on full blast, the car will idle around 1900rpm. If I turn the heat off completely, it will drop down to 1400rpm.
I really have no idea what the problem might be. Every once in a while it will just idle normal as well, right around 600rpm. I am stumped, any input would help. Thanks.
steve_o1989 is offline   Reply With Quote
Old 11-09-2007, 01:47 PM   #2
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
i had the same problem but i didnt rev as high nor did i have a/c. it was a vaccume leak, dirty iacv, clean throttle body, and cts. u might want to search harder.
supreme_1 is offline   Reply With Quote
Old 11-09-2007, 02:01 PM   #3
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
a vacuum leak is one possible reason why you idle so high. check your tps as well. also make sure that you have enough slack on your throttle cable so the throttle isnt stuck open. just a couple ideas...
smurfgcr is offline   Reply With Quote
Old 11-09-2007, 02:05 PM   #4
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
Try the idle adjustmen screw which is right behind the iacv. And search "idle"
read the threads and there are tons of solutions
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 11-09-2007, 03:08 PM   #5
steve_o1989
Thanks for the replies. I'll try searching a little harder and see what I can come up with.
