Old 11-12-2007, 12:22 PM   #1
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
S15 Cluster Sig Converter
THIS DOES NOT COVER FITTING IT IN THE DASH
S15 Cluster Converter
The issue with the S15 cluster being used in a S13(91+)/S14 is the speedo signal and temp gauge signal.
First here is the schematic:
Here is the part list:
Part Value
C1 0.01U
C2 0.01U
C2A 1U
C2B 1U
C3 0.1U
C4 1U
C5 0.1U
C6 0.22U
C7 0.22U
C8 0.1U
C9 0.1U
IC1 LM340H-05 or LM140A-05
IC2 LM340H-12 or LM140A-12
IC3 74LS109N
IC4 LM331N
IC5 LM2917
R1 100K
R2 10K
R3 100K
R4 470
R5 100K
R6 47
R7 6.8K
R8 10K
R9 6.8K
R10 5K
All resistors are 5% or less and all the caps are ceramic or tantalum.
This is needed to keep the temp coef down. It can get hot under the dash.
Now lets get into what everything does.
-Power and logic levels-
IC1 and IC2 are the volatge regulators. IC2, C7 and C8 regulate the input voltage
to 12v which is used for power to the LM2917 and LM331. IC1,C6 and C5 then regulate
that to 5v for logic high and power for the 74LS109N.
-Input frequency to voltage converter-
IC5, R1, R2, R4, C9, C1, C2A, C2B are used to convert the speedo input from a
zero crossing signwave to a voltage.
C9 is a filter for the input since its really noisy. R4 is for voltage dropping
sice the LM2917 has a 7.6v internal zener regulator.
The output voltage is defined by Vout = Vcc * Fin * C1 * R1 * K
where K = 1 and VCC = 7.6
The output ripple is defined by Vripp = (Vcc / 2) * (C1/(C2A+C2B)) * (1 - ((Vcc * Fin * C1) / I3))
where VCC = 7.6, I3 = 180uA, Fin = input freq 4.5hz(1mph) - 810hz(180mph)
-Voltage to frequency converter primary-
IC4, R3, C3, C4, R5, R6, R7, C2, R9, R10 are used to convert the voltage back to a frequency.
That frequency is defined by Fout = (Vin/2.09) * ((R9+R10)/R5) * (1/ (R7 * C2))
Where Vin = Vout from the F-to-V converter.
R10 is adjustable so the conversion factor can be fully adjusted.
R6 and C4 are used to keep the internal referance stable.
R3 and C3 are for input filtering.
-Signal conditioning-
IC3 and R8 are used to form the 50% duty cycle square wave. IC3 is a dual J/K
flip flop so the output will change its state once per pulse and dividing the
primary output freq by 2. This is needed because the output pulse width from the LM331
is too small.
Output here should be 12.5hz/mph
-ECU speed signal-
I did not put this part in because i dont need it and i dont care about it.
But if you want to make it you can. It will be the same as the Voltage to frequency converter primary
section except for different values for R9 and R10. The output will be fed into the second half of IC3
(remember its a DUAL j/k ff).
The output of IC3B will need to be 0.5hz/mph (still cant figure out why the ECU would want such a low resolution)
The input of this whole stage would be fed from the R3 and R2 junction.
Nothing bad happens from not having this, except a no speed sig fault and never have a fuel cut.
That basicly covers to Converter portion. Remeber to use good parts and to use actual measuments for the
formulas and calibration.
-Wiring-
This can all be had from the FSMs, except for the speedo hookup. S13 have 2 wires for the speedo.
On a 89 S13 they are pin 6 (yellow/blue) and pin 12 (yellow/black). One of these needs to be hooked to ground.
Its doesnt matter which one but i used pin 12. Pin 6 will now the the input for the converter.
For the temp guage to work correctly see post #28
Let me know if you have any questions or problems.
Remember this is all free and if you screw something up, its not my fault. Yes it all works in my car.
xsparc is offline   Reply With Quote
Old 11-12-2007, 08:27 PM   #2
Bad40r7
Bad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymoreBad40r7 is not welcome here anymore
Are you willing to do this conversion into a "plug and play" style for us? Pm me if you are.
Bad40r7 is offline   Reply With Quote
Old 11-12-2007, 10:37 PM   #3
trsilvias13
you are low on gas? hehe..
plug and play for us please?
Old 11-12-2007, 10:50 PM   #4
projectdrifter
projectdrifter's Avatar
projectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of lightprojectdrifter is a glorious beacon of light
Send a message via AIM to projectdrifter Send a message via Yahoo to projectdrifter
we want plug and play.. i will pay for an s14 setup.. just give my the paypal buddy.
Mouth of the South
There are a few mailboxes that have been looking at me the wrong way, lately. Nothing goes unchecked.
projectdrifter is offline   Reply With Quote
Old 11-12-2007, 10:57 PM   #5
xsparc
xsparc's Avatar
hey i was sooo happy the gas light worked, the one in my original cluster didnt work for sooo long.
im not going to be making these for anyone. if someone else wants to do it then go for it.
Old 11-12-2007, 11:13 PM   #6
diomedes
diomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to behold
Great diagrams and write-up man. If you had done this like 2 years ago, I would've kept my s15 gauge. +1 for you.
diomedes is offline   Reply With Quote
Old 11-12-2007, 11:34 PM   #7
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Amazing...
But a little too technical for me... Marco from SR20 store will do it for $300...
Nikeboy355 is offline   Reply With Quote
Old 11-12-2007, 11:47 PM   #8
projectdrifter
i wonder if there is any east coast guys who can do it. like south east guys.
Mouth of the South
Old 11-13-2007, 11:02 AM   #9
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
i can probably make this plug and play but they'll be slightly diff for s13 and s14, let me look up the cost of these buggas
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 11-13-2007, 06:53 PM   #10
Bad40r7
^^Ill pay, let me know
Old 11-13-2007, 08:25 PM   #11
NvIs
NvIs is a well-known jackass
Wow mad props. I read on the other post that you made it yourself... thats very impressive, where did you go to school for this?
I don't suppose the chips are hard to find although some maybe harder than others, so I assume most everything, except maybe one of the chips, can be purchased at radio shack. And Just for comparison of the $300 that Nikeboy said, how much did all the parts cost you?
NvIs is offline   Reply With Quote
Old 11-14-2007, 03:40 PM   #12
projectdrifter
what all would be major diffrences in the s14. i wonder if a computer shop could put this together. they soder boards and chips together every day.. could someone possibly point me in the right direction to having someone do this..
Mouth of the South
Old 11-14-2007, 07:21 PM   #13
pbcstylez
the issue here is how nice do you want it to be?
sure i can make one on a breadboard similar to xsparc, but i was actually looking to cut out PCBAs vs using a breadboard. you can do this yourself just go to fry's electronics to get the bread board than order your ICs and passive components through arrownac.com
Old 11-14-2007, 07:51 PM   #14
ZooMxxl
ZooMxxl's Avatar
ZooMxxl is making a name for him/her selfZooMxxl is making a name for him/her self
were there extra steps in making this read in mph?
ZooMxxl is offline   Reply With Quote
Old 11-15-2007, 12:46 PM   #15
pbcstylez
the mph conversion is done using the steps he provided, the only additional steps would be to hookup the ecu speed sensor
Old 11-15-2007, 04:11 PM   #16
240sx_sr20det
240sx_sr20det's Avatar
240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection
if you make this plug and play let me know! ill pay!
240sx_sr20det is offline   Reply With Quote
Old 11-16-2007, 10:18 AM   #17
origin_s135
origin_s135's Avatar
origin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfection
x2
msg length
-robo
origin_s135 is offline   Reply With Quote
Old 11-16-2007, 12:52 PM   #18
pbcstylez
Originally Posted by origin_s135 View Post
x2
msg length
since you're a local guy, if you happen to have a s15 cluster, i may be willing to do yours for a minimal cost (parts only) just to figure out how itll all work together. PM me and we can work something out
Old 11-16-2007, 09:39 PM   #19
Laxman
Laxman is an unknown quantity at this point
Count me in too for a plug and play...
Laxman is offline   Reply With Quote
Old 11-21-2007, 10:17 AM   #20
ichibans13.5
ichibans13.5's Avatar
ichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choicesichibans13.5 has made poor choices
i would be in to price dependent
ichibans13.5 is offline   Reply With Quote
Old 11-21-2007, 11:08 AM   #21
xsparc
xsparc's Avatar
im not gonna say what it cost me to make it, dont wanna hurt anyones profits. but i was no where near what race shops charge for speed signal converters. the most expensive thing was the cluster itself, $150. if you look up the parts i used on digikey.com youll see what it cost me.
making a NICE plug and play one is where the extra cost will come in. getting a profesional board made out where i am is about $100, plus the cost of the nissan connectors and the case might make it expensive.
I didnt go to school for any of this. granted ive been messing with electronics for about 15 years. first i read the FSMs, then i used a o-scope to look the signal from the speed sensor and measured it for mph whith the car on jackstands. then i used a function generator to find the right freqs for the cluster (i got the signal type from the fsm). google is a wonderful thing, i just looked up frequency-to-voltage converters and voltage-to-freqency converters (since i needed 2 back to back, freq-voltage-voltage-freq), read all the spec sheets, did the math that they said to do for the conversions. then built it and tested it.
everything just takes effort and time, thats how mountains are turned to dust
Old 11-21-2007, 07:51 PM   #22
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
looks cool, id get one..
put that steering wheel.... eww... lol
Chrischeezer is offline   Reply With Quote
Old 11-21-2007, 08:24 PM   #23
NvIs
thanks
So I'm assuming you didn't use anything from the s15 harness like the connectors that would plug into the cluster. You just did straight wire to wire connections.
I saw you didn't have a case on yours, but wouldn't the heat build up from behind the dash effect diodes or resistors even though of there 5% reduced?
Do you have any more pics of the wiring?
Thanks
Old 11-21-2007, 09:25 PM   #24
xsparc
xsparc's Avatar
my cluster came with the plugs and a few inches of wire. the s13 plugs wont fit in the s15 cluster.
the parts i used have a high heat tolerance, upwards of 140c, so heat really isnt an issue.
i didnt put a case on one because i didnt have one, i just covered it in hot glue so it wouldnt short out on anything.
Old 11-23-2007, 01:13 AM   #25
NvIs
Yea thats what I thought, you only need the end that connects to the cluster, the other end doesn't matter. Then you took the plugs from the s13, keep them plugged in but cut the end that plugs into the cluster wire that to the end of the converter (except for one of the wires for the speedo, which is grounded) and take the ends that are already cut from the cluster and wire those to the converter.
Thanks for the Schematics and the reply.
If you don't mind me asking where did you acquire the S15 gauge cluster.
Old 11-23-2007, 01:43 AM   #26
GSXRJJordan
GSXRJJordan's Avatar
looks great, and all the research is done. I used to be an Aircraft Elec Tech back in the day, makes me happy to see that people still use O-scope's and sig gens to solve problems Great work ~
Old 12-07-2007, 08:49 PM   #27
zoomswimmer
zoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-known
Did you get your parts from digikey? If so, do you have part numbers?
Thanks
zoomswimmer is offline   Reply With Quote
Old 03-05-2008, 08:34 PM   #28
xsparc
xsparc's Avatar
Ok i got the temp guage working for me. If your temp guage is reading max hot then try this.
I dont know what the normal op temp for the 240 is but im guessing its about 90-110c since the thermistat opens around 70c.
I ran the car up to 97C and took a measurement of the sender, mine read 24 ohms. then i ran it up to 115C, the sender then read 17ohms.
So we want the guage to read in the normal position at 24ohms and about 3/4 at 17 ohms. Now the fun part... remove the board from the back of the s15 cluster and flip it over.
Locate R19, its a large 330ohm resister near the top left. This is the temp guage ref resistor, since the guage is reading high, we need to lower this. You can replace it or put another one in parallel. I found that if you add a 150 ohm resister in parallel it will read just about right on target.
You can adjust it if you want to find a good spot for you. I first tried another 330ohm, but it didnt read hot till around 125c.
If you guage works fine then you dont need this, maybe i just had a bad guage or something since the s13 and s15 senders have the same ranges according to the FSM.
Old 08-12-2009, 04:05 AM   #29
mAchiNE
mAchiNE is an unknown quantity at this point
Hi there, I am new to this forum and love what you have done with this sig converter!, I am in the process of doing this myself but have a question about the output. Here in New Zealand we measure speed in Km/hr not miles and I see you have set this for miles/hr. in the first post you said "R10 is adjustable so the conversion factor can be fully adjusted." does this mean that I can adjust this to make the output accurate for Km/hr? if so how do I do that? Thanks
mAchiNE is offline   Reply With Quote
Old 08-12-2009, 04:10 AM   #30
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
Instead of soldering the resistor in, could have simply swapped the original sensor for the s15 sensor. Granted it's cheaper to solder in the resistor, it may be easier for those who prefer not to modify the cluster.
Somewhat old post but fantastic breakdown and explanation.
Edit: Looks like the S14 KA temp sensor works perfect.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
