Old 11-18-2007, 11:39 AM   #1
1985zcar
1985zcar's Avatar
1985zcar is making a name for him/her self1985zcar is making a name for him/her self
Send a message via AIM to 1985zcar
Quick question about stretched tires.
I'm running a 215/40 on a 17x9 rim...
Discount just mounted them for me the other day, and they only put 29 psi in the tires.
What I was wondering is if it's reccomended to run a lower psi when running stretching tires? Or higher and they just didn't fill em up cuz they're lazy or something?
Tire says max psi is 51...Should I add air or keep the psi low like it is?
Thanks in advance for the help.
1985zcar is offline   Reply With Quote
Old 11-18-2007, 11:57 AM   #2
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
I'm not a wheel and tire guru, but 29psi sounds good since the tire is stretched around the wheel. Plus when driving around, the tires will warm up and the pressure will increase a few psi. So its like running 30-32ish, which is normal.
louisdaboois is offline   Reply With Quote
Old 11-18-2007, 11:59 AM   #3
Dousan_PG
Dousan_PG's Avatar
u run the same pressure u would for any tire
29 to 32 is fine when cold.
Aaron
Pink GodziRa
Old 11-18-2007, 11:10 PM   #4
1985zcar
1985zcar's Avatar
Alrighty, is running higher dangerous or anything? I normally run 35, 29 just seemed sorta low to me, but it was pretty cold today (mid40s probably)
Old 11-18-2007, 11:16 PM   #5
SHIFT_Slide
SHIFT_Slide's Avatar
SHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really niceSHIFT_Slide is just really nice
Send a message via AIM to SHIFT_Slide Send a message via MSN to SHIFT_Slide
Lmfao I remember when Russell said run 5 psi over what the max says on the sidewall. Wonder who actually did that. Run 30 psi.
SHIFT_Slide is offline   Reply With Quote
Old 11-18-2007, 11:22 PM   #6
McRussellPants
Uhhhhhhh, nah man, you have to run 70psi+ or it will unseat.
anyone willing to die can try to run 29, but I don't want my bead unseating on the highway or some shit.
Maximum pressure on the sidewall is to get the peak load rating, you'll have less load rating running stretched tires at 70, but its safer and its not like you're gonna be pulling a trailer or something.
McRussellPants is offline   Reply With Quote
Old 11-18-2007, 11:44 PM   #7
Dousan_PG
Dousan_PG's Avatar
hahahahahahahahahaha
Aaron
Pink GodziRa
Old 11-18-2007, 11:48 PM   #8
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
oh snaps! i didnt know discount tire can stretch tires!
i
markyboi is offline   Reply With Quote
Old 11-19-2007, 12:03 AM   #9
SHIFT_Slide
Yah, it's true Russell is right. The higher the psi the safer you are, disregard what everyone else says. You'll be safer this way. We really don't want you to die.
Old 11-19-2007, 12:06 AM   #10
1985zcar
1985zcar's Avatar
Sweet...I love how the tech section is made just for you guys to flame, what's the point.
Discount doesn't always do stretches, but I have a friend that works there that helps a lot of the locals out.
Old 11-19-2007, 12:36 AM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I hope you know theyre kidding right. Most id shoot on those is 35-36. Only thing with stretching tires is you have to keep an eye on the pressure. If you have a small puncture/leak, the tire could be liable to you unseat the bead.
CLICK HERE!!!
