Old 11-20-2007, 01:47 PM   #1
str4g63
str4g63's Avatar
str4g63 is an unknown quantity at this point
Send a message via AIM to str4g63 Send a message via MSN to str4g63
Power FC User's help
I just installed my power fc on my zenki/s13 red top (62 ecu) and I wanted to know before I turned it on what settings I should put becuase I not fully stock. The fc is supposed to come with a base map.. Mods are as follows..
Injectors 550cc
z32 maf
28 turbo
fmic
exhaust
well the basic bolt ons.. I hope you guys can help..if you need any more info let me know.. also if I can't at least make drivable would I be able to use my stock ecu with the z32 maf.
str4g63 is offline   Reply With Quote
Old 11-20-2007, 03:47 PM   #2
str4g63
str4g63's Avatar
Never mind, Just read apexi pdf.. wont run unless its completly stock.. but thanks.. I still would like to know if the z32 maf would work with a stock ecu though if anybody knows....
Old 11-20-2007, 07:39 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Nopes, Z-maf needs something to correct it for the stock ECU to work. I imagine theres something in the power fc to do so.
CLICK HERE!!!
Old 11-20-2007, 09:52 PM   #4
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
step one go the settings then airflow and choose your maf then go to injector and set your corrections and lag time
blownmotor is offline   Reply With Quote
Old 11-20-2007, 10:11 PM   #5
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
You need to set the MAF type and dial in your injector correction if not she will not idle or run right. After dialing in your setting let it idle.
MADE is offline   Reply With Quote
Old 11-20-2007, 10:41 PM   #6
A'PEXi
A'PEXi's Avatar
A'PEXi will become famous soon enoughA'PEXi will become famous soon enoughA'PEXi will become famous soon enough
yeh, there is a section to select the z32 afm... on default it will be standard...
as for your injectors, calculate the correct % in comparison to your standard injectors... this should allow you to drive to the tuner... i have the formula sitting at home somewhere :P
A'PEXi is offline   Reply With Quote
