Old 12-04-2002, 11:05 AM   #1
JRTurbo909
JRTurbo909 is an unknown quantity at this point
Okay, so the guy who i bought my car from put that ugly purpleish tint on the car and  deperately wann get it removed. Every where I called about says they will charge me $70. I wanna do it myself. Does anyone know any good techniques that may help me. Thanks in advance for the help.
Shah
JRTurbo909 is offline   Reply With Quote
Old 12-04-2002, 11:14 AM   #2
Annoying Eric
Annoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura about
Send a message via AIM to Annoying Eric
When i bought my car it had tinted windows and i just peeled it off..
It should either peel off or use a hair dryer and slowly peel it off, if theres any tint on the rear windows where the defroster things are, make sure not to damage those when peeling it off..
Annoying Eric is offline   Reply With Quote
Old 12-04-2002, 11:19 AM   #3
uiuc240
uiuc240's Avatar
spray some ammonia/water solution on the tint, let it soak, then peel it right off.  the ammonia breaks down the adhesives.
read this
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
Old 12-04-2002, 11:20 AM   #4
JRTurbo909
Was it really difficult to do? So, do you think a hair dryer and a razor would do a good job?
edit: thanks for the link on the ammonia.
Old 12-04-2002, 11:25 AM   #5
AKADriver
AKADriver's Avatar
The tint film itself rips off in big pieces usually.
The problem comes with the adhesive that's left behind. &nbsp;It took me a couple full afternoons to get that crap off. &nbsp;Pick up a bottle of ammonia and some razor blades and go at it. &nbsp;Heaven help you if you've got a fastback! &nbsp;Around the defroster wires here's what you can do (because you don't want to use a razor blade around the wires, like I did... oh well it's a summer car). &nbsp;spray the ammonia over a section. &nbsp;Slap some clingy plastic wrap over it. &nbsp;Continue on until you've got the whole window covered. &nbsp;It helps if it's a nice sunny day. &nbsp;If you've got a fastback, close the hatch to trap the heat in... don't worry, the ammonia smell goes away <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp;Let it sit for a half hour or so... &nbsp;have a beverage, work on another window, whatever. &nbsp;Then come back and peel off the plastic wrap. &nbsp;The ammonia will have completely dissolved the tint adhesive. &nbsp;Wipe it all off, and then clean the window normally with a good glass cleaner.
