![]() Hi guys I have an s14 with a redtop, currently everything is stock except for a t28 turbo upgrade.Here is what is happening. The car starts an idles great but once it goes around 2500 rpm it starts bogging and no power.
-Here is what I checked Any boost leaks by spraying it with carb cleaner ignition timing fuel pressure and fuel pressure regulator cleaned maf -I replaced spark plugs I have hooked up the nissan consult scanner and it says it is running lean. I dont know what to do and I am afraid of ruining my motor. This problem just started on its own. Any ideas? BTW how can I check MAF?? |
![]() Join Date: Jul 2007
you bolted a t28 turbo to an engine that is tuned for a t25. this turbo has the ability to force MOAR air into the engine. now with this larger turbo you've bolted on that can force more air, have you done anything to your fuel system to match the larger volume of air coming into the intake?
this won't fix your problem, but you should definitely have a higher volume fuel pump. you either need to get an AFC (air/fuel controller) to tune with to tune your a/f ratios, this will allow your engine to run a little more stable. maybe a cheaper route would be an adjustable FPR, but i'm no tuning expert. your engine probably idles fine, but once it hits boost, it dies because you're way too lean, because too much air is coming in and not enough fuel. also do you have a boost gague? if so, do you have a boost controller? what are you currently boosting?
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
consult was nissan's pre OBD standard diagnostic tool.
you really don't need it as you can check CELs right on the ECU and you have zilvia to tell you what is wrong with your engine. i myself am pretty impressed the OP has one. the only useful information i've found about the CONSULT is here: http://plmsdevelopments.com/consult_if.shtml
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
check your maf you might need to upgrade your maf and fuel pump. also you might need to check your fuel filter might be clogged
FS Exhaust, Q45 ignitors, & MORE! |
i know this is offtopic but can someone please answer me this...
there are times when my shift knob bobbles like crazy and the same for my motor .. i foudn out that when i play around with the ignitor it stops ..and then it continues on again...since the ignitor is just hanging im assumin the wires get loose and give me a bad connection causing my car to idle or run like crap....for example it sounds like a subi thanks for any info u guys might bring to the table :] |
See here is the weird part, It was running like a champ before but after leaving it for a couple of days without driving it now I have this problem.
Consult is a very usefull tool that lets u do alot more than just pull codes, I use it cause I work at a dealership. |
#12 | |
BUUUMP!! anybody!!? |
#13 | |
![]() Join Date: Dec 2006
Maybe combonation of broken Motor/Tranny Mounts In this situation it your MAF if it wont go above 2,500RPM's and falling on its face. Thats a $350+ ignitor chip Id secure that some where before it gets destroyed
#14 | |
Im running a T-28 on Stock ECU, MAF, and Injectors, @ 1.0Bar DD with no problems for 6 months now. Sure a Z32 MAF and some 550's with a Tune would be good, But You can DD/ Race a T-28 with out problems, on a Stock SR depending on the condition of everything.
#15 |
Sorry to bring this thread back from the dead, but I found out whats wrong, not right now, but never post it, future members may find this information useful.
The problem was spark plugs, I bought new NGK and the car is running GREAT! |
#16 |
![]() Join Date: Sep 2005
Wrong! What do you take us as... Idiots? And members if you take anything from this thread take this... If you have problem at 2500rpm check your mafs first!
