usdm climate control modes malfunction
i have a 95 240sx. cant figure out this problem on the usdm climate control. air just comes out through the front vents only. the only other functioning modes are the fresh air, a/c, and the temperature controls. i replaced the climate control and the motors under the dash but still nothing. anyone have an idea what the problem is? its bugging me because when my windows are fogged up i cant defrost...
![]() Join Date: Dec 2002
You did replace the mode door motor? That's in charge of directing airflow, nothing else would cause the issue you're having.
Im having the same problem in my s13, so far ive changed out the climate control and mode door actuator, im not getting power to the mode door actuator, now im trying to find a fsm w/d to check it out keep us updated
There must be an object stuck in the door, or the linkage is bent/kinked. I've never seen a problem and it not be electrical, that's weird. Pull the mode door motor off and manually work the linkage, does it move freely or does it bind? Does it move the full range or does it stick partway?
#6 | |
Its not the mode door actuator, i ran the linkage on the blower everything operates like butter, im not getting power at the mode door actuator plug, im assuming that the OP is having the same problem that i am, i guess ts a electrical problem is there a relay or a fuse etc left to check? im still trying to find a FSm wiring diagram that has a good download link haha, if not i guess i have to pull the dash and start chasing wires ![]() ![]() ![]() ![]() |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
zeroyon.com has working links.
ok zeroyon doesn't work, try skylingking.com http://skylineking.com/info.html
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
#8 | |
Were you able to get a copy of the wiring diagram for the mode door actuator?
