#61 | |
isnt 315's about 11.50" - 12.00" wide? I don't have 315's but I am Running 11.50 M:T drag Radials!! I am running a 35mm offset. |
#63 |
![]() Join Date: Feb 2003
Those 315's on a stock fender is nuts.
I was just about to try and fit something at least 295 all around on the evo but now that 315 tire has me thinking.
#65 |
![]() Join Date: Mar 2003
i believe they are CCW's
http://www.ccwheel.com/files/home.php edit: now i'm sure they are http://sccaforums.com/forums/thread/262961.aspx CCW "track classics" 18x11" front (approx. 20 pounds), 18x12.5" rear (approx. 22 pounds) 285/30-18 front, 315/30-18 rear Hoosier A6 tires |
#67 |
Nice ride Black Is Sexy!!!!
#68 | |
![]() Join Date: Sep 2007
mmm CCWs...that thing got a V8 in it? Looks sick ![]()
#69 |
Someone needs to post up Sasha's setup, here goes. His racecar was 18x9.5 RPF1 front with 275/35/18 RA1 and 18x10.5 rear with 305/35/18. Not sure on offsets, check ziptied if you really want to know. Worked well for his endurance racing purposes. I'm assuming since he recently parted the car out and was selling lots of damaged body parts that it got crashed.
![]() ![]() Full Race/Brady time attack S14: 17x9 +17 MB Weapons, 275/40/17 slicks all around ![]() My car: 17x9 +17 MB Weapons, 245/40/17 Kumho MX all around, rolled fenders, car a little bit too low for my tastes so I have some rubbing up front at full lock. I want something like Sasha's setup next with some used R comps. I got this current setup because it was cheap and a sure thing as far as fitment goes. ![]() Last edited by turtl631; 12-06-2007 at 05:05 PM.. Reason: To edit my post |
#70 |
YOUR CHASSIS: s14
WHEELS: Nismo LM GT4 - TIRES: Maxxis 265 / 18 / 30+ 5mm spacers up front PURPOSE OF CAR: everything I'm going to try to fit 285 / 30 / 18 in the rear. Otherwise, if anyone has ever done so let me know. |
#72 |
Banned from the Marketplace
![]() Join Date: May 2006
285's on a LM GT4? I hope you have a 10" wide LM GT4 because I have them too and I'm running 9.5" back (common size) and 275 is the biggest you can safely go.
#74 |
Whatever, I meant at least a 10" wide. I do not remember the exact widths they come in, but the most common are 8.5 front and 9.5 rear. And upon further investigation a 285 MIGHT fit depending on the tire, but it'd be a little too big to fit on the rim if it was me.
#76 |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
Finally!!!!!! A thread where I don't have to explain why I didn't buy a 10" wide wheel with +0 offset and a frigging 225 tire stretched around it
![]() First setup: Wheels: WedsSports TC-005's 18x8.5 +32 18x10 +44 Tires: 245/40 and 275/35 Suspension: Cusco Coilovers Power: 400whp Daily driven with some track Rolled fenders front and rear ![]() ![]() ![]() New setup: Wheels: Work Meister S1 2P's 18x8 +32 A-disk(for the big brakes) 18x9.5 +44 O-disk Tires: 235/40 and 265/35 ![]() ![]() ![]() Last edited by Broadfield; 04-01-2009 at 03:40 PM.. |
#77 |
You can definitely go bigger than 275 on a 18x9.5" wheel. Stock class autocrossers with RX8s and Solstices with 18x8" wheels run 285/30 all the time. Most 285/30s are rated for use on a 9.5" wheel. It might not have the best contact patch on a wheel that's on the narrow side of its rated range, but it will fit on there and be safe.
#78 |
![]() Join Date: Apr 2005
i noticed essentially autoX, and drag guys posted there setup. yet I've only seen one road race minded car (that being sasha, who has a z33 to race with for next season). I know in some instances you are limited by tire width due to class and what not. The point of this thread seems lost to me, with out at least digging into the area where jason rhoades and aceinhole really spend the money on. suspension. what good is having massive amounts of rubber if the suspension isn't up to the task.
275 isn't necessary on our cars. hell if we are road racing 255/40/17 RA1 or NT-01s should be fine enough without going widened fenders.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! ![]() formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 ![]() |
#79 |
This thread is about large wheel/tire fitment, not an overall strategy for building a track car.
Aceinhole had D2 coilovers until very recently. Clearly, big tires were of benefit to him despite his less-than-ideal suspension. Have you tested various tire widths by comparing track times? Sure, 245s or 255s are probably adequate and the best choice for most, but that's not to say that larger tires won't turn faster laptimes. I'm guessing Sasha wasn't running 275 f/305 r just for looks. |
#80 | |
#81 |
CAR
s14 stock body just pulled WHEELS Work meister S1 3 piece front 18 by 10 + 18 Rear 18 by 11 + 18 TIRES front 275/30/18 Rear 315/30/18 SUSPENSION Tien coilovers Rear ARms Solid subframe ALIGNMENT front zero toe 2.5 degrees Rear zero toe 1.5 degrees CARS USE Drift / Drag / Grip Pretty much everything but daily ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#82 |
very nice thread...i need some wider rubber on the back of my s13
i have a 16x8..im gonna check the offset and ask for opinions... Jeff
89 silvia/1JZGTE 6765 dbb E85 527rwhp |
#83 |
![]() Join Date: Sep 2005
gsracer FTW!
I run 275s on my 9 inch rims, and would have to concerns about saftly running a 285, 285 would be considered... but with low profile tires you start to push it there if you want to handle. My car sees the road course. I dont go door to door racing, but do HPDE. I also do 6-7 drag days a year, and 7+ auto-x.
#84 | |
Instead of going 10mm wider (doesn't do that much) just get a stickier compound. |
#85 |
![]() Join Date: Mar 2005
this thread is awesome. when i get my HX35 on, and re-tuned. ill be looking for this thread. my 225's are barely cutting it now. this shit is inspirational. i hate extreme fender mods. but i need some fatter tires.
-Dane |
#86 |
I didnt say i needed to go bigger. I was saying that I wouldn't have any concerns with going bigger then the size I have on a 9inch rim. Like earlier someone stated that its not safe to have a 285/295 on a 9.5 rim
#87 |
I don't have any pictures but on my s14 i have 18x9.5 with +12 offset MB Drifter wheels and 275/35/18 yokahama advan neova's on all 4. the front has wide body fenders and i pulled the rear out about an inch with a fender roller. i had to run about -2.5 camber in the front and about -2 on the rear. on the rear there was still room to go in about an inch in and use wider-less offset wheels. probably could have fit 315's under there. but i like the way it looks now.
#88 |
![]() Stock suspension ![]() after coilovers and control arms ![]() BBS E26 GT2 race wheels Front 17x9.5 245/40-17 Rear 17x10 275/40-17 I have the wheels off the car because they have broken. ![]() 50mm rear fenders and 20mm front fenders(not enough, I'm going to end up making custom ones to fit 275's in front) I use the car for Track events and its my back up car when my super reliable BMW M3 breaks down. I have aspirations of racing it in NASA PT series in a couple years.
- Ted Last edited by RedSVTFlareside; 12-12-2007 at 03:08 AM.. |
#89 | |
Drifterella
#90 |
I'm really not sure exactly... I measured them once a few years ago. I think it was something like +12 in front and -6 in the rear. My numbers could be off. They aren't really sold with offset sizes; you order the rim halves by width. The front fit without a spacer but it is very close to the coilover, I couldn't add any more to the inner rim half. There is plenty of room for more inner rim on the rear though.
Front - outter rim - 1.5 inner rim - 8 Rear - outter rim - 3 inner rim - 7 I'm ordering new outter 2" halves for the front and 9" inner halves for the rear. I had one fatigue crack on me. See the crack going through all the bolt holes. So I decided to go for maximum width since I'm ordering new parts anyway. ![]() As a note I didn't order the current sizes. I picked up the wheels 2nd hand from a 2001 ford mustang GT2 racecar. That is why the wheel offset isn't quite ideal yet.
- Ted |
