Old 12-03-2001, 05:27 PM   #1
STL240SX
STL240SX is an unknown quantity at this point
i dont really want to deal with the hassle of trying to drop the SR into my car because i dont think i could get it to pass the stupid emmisions testing, so i guess i just goingto stick with my KA for now. Anyway, i know im going to have to fix my timing chain soon (its getting increasingly annoying). so yo guys think i should just fix that, and a few other things, fuel injectors, etc... or just keep saving and do a full rebuild??  What do you guys think??
STL240SX is offline   Reply With Quote
Old 12-03-2001, 05:34 PM   #2
mistert
Pearl White Mike
mistert is an unknown quantity at this point
Send a message via ICQ to mistert Send a message via AIM to mistert
hmm...you could get new injectors, but it'd be cheaper to just have yours rebuilt and blueprinted. im not sure how much a crank balancing costs...it shouldnt cost much at all to do a .030 bore of the cylinder walls though. i dunno...i'd just save up my money for a swap. you shouldnt have problems with emissions...
mistert is offline   Reply With Quote
Old 12-03-2001, 05:36 PM   #3
gwong
gwong is an unknown quantity at this point
Hey are you in St. Louis?  What year's your car?
gwong is offline   Reply With Quote
Old 12-03-2001, 05:38 PM   #4
STL240SX
yep, im in STL i have an 89 hatchback.
Old 12-03-2001, 05:40 PM   #5
STL240SX
Old 12-03-2001, 05:44 PM   #6
gwong
Hey I have a turbocharged 95 S14 with a rebuilt KA24DE.  Let me know if I can be of help.
Old 12-03-2001, 05:49 PM   #7
STL240SX
well what do you think, just fix the timing chain, and get some bigger injectors, and all that, or save a little more, and just rebuild the whole thing??
Old 12-03-2001, 06:37 PM   #8
mistert
Pearl White Mike
ouch...the elusive triple post
Old 12-03-2001, 07:35 PM   #9
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
Hmm, haven't seen that before, I'll take care of it.
btw, I'd go for a rebuild. It's in my future, as well as higher compression pistons. Personally I don't want to overbore because the piston walls are a bit thin.
transient is offline   Reply With Quote
Old 12-03-2001, 08:13 PM   #10
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
i'd get 10.5:1 compression piston heads, and have everything else checked out, and a cam from pdm-racing.com.
whateverjames is offline   Reply With Quote
Old 12-03-2001, 08:21 PM   #11
mistert
Pearl White Mike
a .030 bore wouldnt prevent you from using stock pistons at all, and wouldnt compromise your cylinder wall integrity. it'd just be to clean the cylinder walls and get rid of any nastiness in the compression chamber that could mess with airflow and such...it would afford a couple extra lb/ft of torque, probably, but thats not eh whole point of it. i dunno if i was staying na, though, i would get some overbored pistons and that little bore out, like a .25mm. i dont think the static pressure ratio would be able to blow your engine at these levels, unless you planned on running n2o part of the time.
Old 12-03-2001, 08:25 PM   #12
jay
jay is an unknown quantity at this point
I am in the same position, when I go back home for christmas I will be changing my  timing belt as well. But I plan to go turbo in the future so increasing my compression wouldn't be too bright but I am, however, going to get a port and polish job. Plus I get my CAI and N1 dual put on!! YES!
jay is offline   Reply With Quote
Old 12-03-2001, 08:27 PM   #13
mistert
Pearl White Mike
dont forget silencers...we're better than hondas <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'>
Old 12-03-2001, 08:30 PM   #14
jay
Are they really that loud? I have video of them idleing and revving and they didn't sound that loud. They for sure do not sound like the farty mufflers on most hondas.
Old 12-03-2001, 08:36 PM   #15
mistert
Pearl White Mike
its not as much as a bad sound, its just too loud. silencers are supposed to give you a little of that backpressure back, too. whether or not this will make any power difference i have never seen. if you go with an SR swap though, you know you dont have to worry about getting a new exhaust, since you already ahve a turbo-ready one.
Old 12-03-2001, 08:38 PM   #16
jay
Yeah, that is definately one reason why I am buying the N1 dual. I would hate to have to buy all new stuff when I do a swap or turbo. That would be hella weak.
