Recirculating setup!
Hey guys thanks for your help in telling me that im running really rich since i have an atmospheric bov, and its not recirculating back! So i was thinking, would it make a difference if i were to recirc it using this part on the IC piping, back to where it recircs to the intake? Thanks a lot guys.
![]() Join Date: Nov 2005
just put it into your intake where the stock one was. now that you put the bov on the hot side. if it were on the cold side i would say go for it
You mean, recirculate the air to that tube coming off the intake pipe? It won't work that way; you should be recirculating to a spot before the turbo, but after the MAF. Like your stock rubber intake tube.
My seller review thread |
Thats what i'm trying to do. I have a rubber hose, that im gonna connect from the red square, back to the stock recirc spot, between the turbo and the maf! Where the old setup was located! Will it work?
...Huh?
You're going to run a hose from the red square, near the throttle body, directly to the rubber intake hose? Do you understand how the BOV works? The pipe has to go from the BOV to the rubber intake tube. So since your BOV is on the hot pipe, you won't be using that part with the red square. You have to get a recirculation fitting from HKS or a vendor, and run the recirculation hose from it to the intake tube.
Like this. Nice and simple. The small vacuum hose running from the intake manifold to the BOV tells the BOV when to open. When you let off the gas and the throttle body snaps shut, the manifold goes from boost to vacuum, and that vacuum pulls the BOV open. The purpose of the BOV is to relieve the pressure in the intake tract (and if you're recirculating, also to avoid losing that air and confusing the MAF). So you have to connect a hose from the BOV, which is mounted on a high pressure area (intake tract after the turbo, which includes your hot pipes, cold pipes, and intercooler) to a low pressure area (rubber intake tube, after the MAF). The BOV simply opens and allows the pressure to equalize between the high- and low-pressure areas.
No it won't. all your going to do with that setup is take air going into the intake manifold and stick it into your turbo, ie BAD IDEA. While your at it loose the stock recerc tube on the front of the valve cover as ther is no need for it. Like I said befor, take that hose put the HKS recerc fitting into your BOV and then go to your air intake. To put it bluntly, Your way WON'T work but mine WILL.
#16 |
![]() Join Date: Apr 2004
Optimal solution without moving the MAF:
1. Remove the BOV from the hotpipe and seal the flange on the hotpipe. 2. Weld a flange on the coldpipe as close to the TB as you possibly can. 3. Mount the BOV on the flange. 4. Run a hose from the BOV to the intake pipe between the MAF and the turbo. If you want to vent to atmosphere, you need to either move the MAF or convert to MAP. |
#18 |
What do you mean, they "integrate it into the intake pipe"?
#19 |
They just have it on the cold side of the charge pipes instead of the hotside like 240's usually have. Same concept just different mounting place. The bov has to placed on a pressurized pipe (i.e intercooler pipe, after the turbo). If it were placed on the intake, before the turbo, it wouldnt do anything.
#20 | |
But generally you want the BOV to sit as close as possible to the TB. You also want the flange to sit as flushed with the coldpipe as much as possible to reduce pressure drop. Any extra distance between the coldpipe and the BOV = slight pressure drop. |
#21 |
![]() Join Date: Jul 2007
wtf are you talking about? your statement makes no sense.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving |
#22 |
If you have the motherfucking BOV between the MAf and The Turbo, with a recirculator, you can shoot the pressure back into your system instead of into the atmosphere like most blow off valves are set up do. Recirculate your shiznit man. Everyone is so fucking quick to talk shit on this forum, fucking fags
#23 |
the exact same thing happened to me but i was running it to the intake like you had asked about and that cuzed probs so jus chop it and have a plug heli arced in did the same thing wit my s14 setup and worked like a charm no it runs mint
#24 |
so wat is that pipe for? on the cold side even for?
is it for oil catch can?
fS! vlsd ! slim fans ! hid kits ! lug nuts ! http://www.zilvia.net/f/search.php?d...earchuser=bo2o ^^^click^^^ |
#25 |
If you put the motherfucking BOV between the MAF and the turbo, it won't do anything because that pipe is not pressurized, it's under vacuum. You have to put the BOV on a pipe somewhere between the turbo and throttle body or else it won't do a goddamn thing. Then (watch this), you run a line from the BOV to the pipe between the MAF and turbo.
If you knew your ass from a hole in the ground and didn't go spreading misinformation, nobody would be talking shit. By the way, this setup 1) is not specific to Evos, pretty much any factory turbo car with a pressure release valve works this way, 2) has nothing to do with spool, and 3) has nothing to do with horsepower. Follow?
#26 | |
#27 |
I didn't neg rep you, hoss. Maybe that's everyone else who doesn't like the way you're blatantly (and angrily) spreading misinformation and advertising the fact that you have no clue how an automobile works.
Whatever. edit: By the way, if you spend $10 to support the forums, you would be able to see who's giving you bad rep for not knowing what you're talking about.
#29 | |
![]() Join Date: Oct 2003
#30 |
![]() Join Date: Aug 2006
is this really that complicated... cant we all just get along lol... the poor guy asked for some help and everything goes KABOOM! hahahahah heres a poor illustration
PARTING/SELLING MY COUPE. PM ME. |
