Old 12-08-2007, 10:50 AM   #1
nammy
nammy is a well-known jackass
brake question...please help >.<"
i have a problem with my stock s14 rear calipers...a few nights ago i had to hard brake cause an a$$ hole in front of me...and i knew my brake pads and rotors are pretty beat...so any ways after that hard brake my rear brake started making like metal to metal grinding sounds...at first i thought i jus needed to pads and rotors but it would still sound like its grinding even with my foot off the brakes...could it be a seized caliper?....and if so can i buy a kit like this to rebuild http://www.autozone.com/R,APP1128425...ductDetail.htm am i screwed?
nammy is offline   Reply With Quote
Old 12-08-2007, 11:03 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
first things first. take your rear wheels off and LOOK at the brakes. from what you stated it sounds like you're metal on metal. or maybe you're just hitting the wear indicator. maybe you should check them out before posting. just a thought.
Old 12-08-2007, 11:07 AM   #3
aznpoopy
aznpoopy's Avatar
+1
you are probably down to the wear indicator
but um, take off the wheel and look first. we can't check your car out for you over the internet
Old 12-08-2007, 11:10 AM   #4
mrmephistopheles
mrmephistopheles's Avatar
Seconding the (preliminary) diagnosis of worn pads.
Identify which corner is problematic.
Remove the wheel.
Inspect the brakes carefully.
Take pics to show us.
Originally Posted by PHLIP
Old 12-08-2007, 03:17 PM   #5
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
had this happen to my beater.....make sure you change the pads asap or else you will wreck the rotors and need them replaced too
njd07 is offline   Reply With Quote
Old 12-08-2007, 04:16 PM   #6
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
+1 replace pads and rotors.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
