Old 12-13-2002, 09:00 PM   #1
DarkRaptor42
DarkRaptor42 is an unknown quantity at this point
My car started pinging today. I havnet changed or cleaned the fuel injectors so i figured that might be the cause. So what im wondering is what else it could be. Thanks
Max
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
DarkRaptor42 is offline   Reply With Quote
Old 12-13-2002, 09:20 PM   #2
Titan
Titan is an unknown quantity at this point
Pinging? As in maybe detonation!?
If you think your injectors are dirty and aren't providing enough fuel, this may be a possibility. In which case, this would be VERY bad... usually a few pings and your engine is done.
How loud is the pinging? What are the noise characteristics exactly?
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 12-14-2002, 12:20 AM   #3
240racer
240racer's Avatar
240racer is an unknown quantity at this point
The first thing to do is think about the fuel you put in, was it different then before?  Also, one easy way to help it stop pinging is to put in the highest octane (92 or 93) you have around you. Also, check the timing, if it is too advanced, then it will ping.  timing information is found at 240sx.org FAQ.  If those things are fine, then move on to more complicated things.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 12-14-2002, 05:23 PM   #4
DarkRaptor42
its not my fuel, the car has been sitting for a few months, nothing has really changed. Could it also be the fuel filter? My pinging is like a poping and a vibration that shakes the entire car. I figured this was detonation, never having experinced it I didnt know what it was. I always put 91 (highest around here) in so i know its not that. Im gonna change the fuel filter and then clean the injectors. Anyone else have anything else I could do?
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
Old 12-15-2002, 03:05 PM   #5
240racer
240racer's Avatar
The fuel might be old, if it started to varnish that might affect something, otherwise I don't really know what to do.  Did you check your timing, it may have slipped.  Is this happening at full-throttle or some other time?
Do you think it might be backfiring?
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
Old 12-15-2002, 03:59 PM   #6
DarkRaptor42
It could be backfirning too, its like i said ive never dealt with detonation before. The fuel has been standing for about a year though, but its all through the RPM range,.
04 WRX STi
90 Sil- Camino
R.I.P. AE86 20v MS
R.I.P. KA-T
www.209forums.com
Old 12-15-2002, 04:38 PM   #7
uiuc240
uiuc240's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (DarkRaptor42 @ Dec. 15 2002,4:59)</td></tr><tr><td id="QUOTE">It could be backfirning too, its like i said ive never dealt with detonation before. The fuel has been standing for about a year though, but its all through the RPM range,.</td></tr></table><span id='postcolor'>
First off, get that gas out of there. &nbsp;Second, is the popping/vibration rhythic? &nbsp;Does it happen consistently? &nbsp;You probably have a misfire. &nbsp;Get the gas out of there, try some injector cleaner, and see if that gets rid of it....if not, there are some other things to look in to.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
