Old 12-13-2002, 12:14 AM   #1
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
Is it possible to buy an oil relocation kit, and run the turbo oil lines off of that instead of tapping the oil pan?  In theory, could I run the turbo feed line straight from the relocation kit, return line to the oil cooler, and then back to the relocation kit?  A buddy at a local shop recommended this, but I don't know if it would be reliable, or a good approach.  Thanks in advance.
"Pure adrenaline attached to a license plate.  Isn't it time to experience one yourself?"
                        -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 12-13-2002, 02:50 AM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
The point of dumping the return oil back into the pan is to allow it to "de-foam" as it gets really bubbly from the spinning turbo (at least this is what I've read...as I can't see inside the motor). &nbsp;I would say this is not the best thing to put through and oil cooler. &nbsp;But you *can* tap off the sender for the supply line <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;Only bummer with that is that it's on the opposite side of the motor.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 12-13-2002, 10:02 AM   #3
Grumpy
Grumpy is an unknown quantity at this point
The short answer is NO!!!!!!!
velocity.isfaster.com[br]www.mckinneymotorsports.com
Grumpy is offline   Reply With Quote
Old 12-13-2002, 11:15 AM   #4
240racer
240racer's Avatar
240racer is an unknown quantity at this point
The oil needs to drain out of the turbo with gravity, so you won't be able to get it to flow through the oil cooler. &nbsp;I drilled out and tapped my dipstick hole, so that's how I did it with out welding on the oil pan, but then you have to figure out another way to check your oil level :-) &nbsp;
I agree with grumpy
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 12-13-2002, 11:56 AM   #5
Tyler Durdan
Well alright. &nbsp;Thanks for the responses, and I'll pass on the kit. &nbsp;I didn't think it would be a good way to do it, or else it would have been done a lot more. &nbsp;Thanks again.
&quot;Pure adrenaline attached to a license plate. &nbsp;Isn't it time to experience one yourself?&quot; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; -Dan Gurney
Turbo for Sale
