Old 12-13-2007, 09:51 AM   #1
antsony
antsony is an unknown quantity at this point
OBDII Error codes, where should i start
My check engine light went on right before i was going to take it into a smog cehck. pulled the codes, here is what i got:
P0325
P0440
P0446
P0755
I figures out what all the errors were but can anyone help out and let me know where i should start first?
antsony is offline   Reply With Quote
Old 12-13-2007, 10:33 AM   #2
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
I don't have my fsm with me, can you tell me what the display said when you check the codes?
-Retired
98s14inaz is offline   Reply With Quote
Old 12-13-2007, 10:45 AM   #3
antsony
P0325 - Knock Sensor
P0440 - EVAP Small Leak
P0446 - Vent Control Valve
P0755 - Shift Solenoid Valve ‘‘B’’
Old 12-13-2007, 11:11 AM   #4
98s14inaz
Automatic ka right?
Knock sensor = replace (might have one laying around)
Evap small leak = check for leaks in the vacuum lines, fuel lines, charcoal canister, gas cap, etc.
Vent Control Valve - probably has to do with the evap, could be the sensor or just a vacuum line.
Shift Solenoid Valve = something to do with the tranny, do manual swap to fix this or look for that small metal thing on the driver's side engine bay and make sure it is plugged in. iirc it is bolted to the the engine bay side of the wheel well with two 10mm. If that is unplugged it will throw that code. Feel free to correct me if i'm wrong, when you get old the memory starts to go.
-Retired
Old 12-14-2007, 08:51 AM   #5
antsony
Whats the easiest way to get to the knock sensor?
Old 12-14-2007, 11:12 AM   #6
98s14inaz
Probably from underneath. iirc it is held on right under the head and intake mani by a single 12mm bolt or is it a 10mm? I can't remember. It is a huge pita though. Find someone with tiny asian hands to help you.
-Retired
