Old 12-13-2007, 04:20 PM   #1
conecrazy
conecrazy is an unknown quantity at this point
G35 brembos brakes will fit on an S14 right?
Cause I came across these 4 pot AP Racing brakes. Sounds like a pretty good deal. Will 17" wheels clear the rotors or will i have to upgrade to 18's?
conecrazy is offline   Reply With Quote
Old 12-13-2007, 04:45 PM   #2
SimpleS14
SimpleS14's Avatar
17" rims minimum required (for stock Brembos..don't know about aftermarket kits) and yes they will fit. If I'm not mistaken you need to retap the spindles.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 12-13-2007, 06:09 PM   #3
projectRDM
projectRDM's Avatar
Drill the spindle holes to 14mm (9/16").
FORMERLY R240NA
Old 12-13-2007, 06:21 PM   #4
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
Here is the thing though. If you are going to spend 1800 dollars on a high end brake setup, why not buy it for the right application. You can get a rotora, grex or stoptech BBK for the 240sx for all around the same price.
If you drill out the spindle, you can never put your stock brakes back on. Say you want to return your car back to stop for some reason, you will have to replace the spindle to go back to stock.
I would feel better drilling out my spindles if I spent 500-600 dollars on a stock 350z brembo setup. Its better than spending 1800 dollars.
garagelu is offline   Reply With Quote
Old 12-13-2007, 06:24 PM   #5
DOOK
DOOK's Avatar
or wilwoods and save some money...
http://www.arizonazcar.com/240sxbrakes.html
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 12-13-2007, 07:32 PM   #6
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
Just FYI Stillen makes a kit specifically for 240's and the MSRP is less than the G35/Z33 applications.
atom is offline   Reply With Quote
Old 12-13-2007, 07:49 PM   #7
MomentumGT
MomentumGT's Avatar
MomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to behold
We run the Brembo F50 kit on our race car and never had to drill out any spindles. The kit was off of a Grand Am Cup Camaro so I just bought the bracket for a Q45 and everything bolted in. Also installed a proportioning valve to get things working where we wanted. We also run 17" rims, which is VERY close. Bent the rim one time and it immediately started grinding the caliper.
-Jon
momentumgt.com - "building blocks of speed"
MomentumGT is offline   Reply With Quote
Old 12-13-2007, 08:06 PM   #8
OptionZero
OptionZero's Avatar
q45 brakes bolt up directly, which is why your brakes bolted up directly
350z/g35 brembos do not bolt up directly, so it figures that aftermarket 350z/g35 brakes will not bolt up directly
OptionZero is offline   Reply With Quote
Old 12-13-2007, 08:16 PM   #9
conecrazy
hmmm.. good point haha i just saw the sale and thought, damn 4 pot APs for 1500 haha
Old 12-13-2007, 08:26 PM   #10
MomentumGT
MomentumGT's Avatar
Off of a camaro not q45 just used the brembo bracket for q45 so no need to drill. Just another option presented.
-Jon
Old 12-13-2007, 09:25 PM   #11
ixfxi
Guest
Posts: n/a
OH NO, cant revert to stock?
when it comes to brakes, i dont think many people ever care to revert.. especially on these old pile of shit cars we own
problem with OE brakes is that they are fucking heavy. the better quality BBK's are pounds lighter and better build quality. i sold my golden brembos for that exact reason, they're pretty on the car.. but too damn heavy.
Old 12-13-2007, 09:40 PM   #12
projectRDM
projectRDM's Avatar
The bolt threads into the caliper. If you do indeed somehow get a wild hair in the ass to put the tiny little OE calipers back on, just cut a 12mm sleeve and slide it right in. Done. No need to replace anything.
I'd put more concern into things that you actually can't change, like World hunger. A spindle needing a bushing isn't a problem.
FORMERLY R240NA
