Old 12-28-2007, 05:34 PM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
Quick Question: Tie Rod Install
Ok I got the outer tie rod disconnected. Now I'm trying to get the inner tie rod out. Is there a trick to it or something? I'm using a large adjustable wrench to try and break and free and holding the steering column part with a set of locking pliers. I tried turning both ways and no luck. Do you turn towards the lower control arm or away from it? I assumed towards it but still no luck. And how much pressure do you need to break them loose? Thanks in advance. I just can't get it free? I got my new tension rods on no problem (I know don't tighten the bolts til it's on the ground)? odd... Well thanks in advance for the help
rocksteady_racer is offline   Reply With Quote
Old 12-28-2007, 05:38 PM   #2
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
http://splparts.com/doc/SPLTieRodEnd/default.htm
hopefully that helps
@adrianfromthecastle
Old 12-28-2007, 05:57 PM   #3
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
when I did mine it took my friend and I to break them loose, so as long as you have that metal clip off, just try harder, lol. G/L
driftyour40 is offline   Reply With Quote
Old 12-28-2007, 05:59 PM   #4
cdlong
it's just righty tighty, lefty loosey like 99% of everything else, but there is a locking clip or loc-tite (or both) on there. just lean on it i guess.
cdlong is offline   Reply With Quote
