Old 01-03-2008, 08:44 PM   #1
koolcat
koolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-known
Send a message via AIM to koolcat
digital cluster help!!!
hi,
i've been searching around but can't find the answer. I am in the process of buying a digital cluster from a 89 240sx sohc engine for my 92 240sx dohc engine. The question is that will the sohc digital cluster works on my dohc engine??? If not is there a way i can make it work? If anyone have the answer or some links for the answer of my question please post it cause im about to buy it but i need this answer asap.
thanks again
koolcat is offline   Reply With Quote
Old 01-03-2008, 08:46 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
remove the tach from dohc cluster
install into digi cluster/
done
sillyvia13 is offline   Reply With Quote
Old 01-03-2008, 09:12 PM   #3
kingyogi
kingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nice
hit up tyler at killswitch performance, hes in the atlanta area.
they do great work as well, get it professionally done :P
687-628-2965
kingyogi is offline   Reply With Quote
Old 01-03-2008, 09:13 PM   #4
koolcat
but does it has to be the tach from a digital cluster or can i use the one from my dohc engine which is analog
Old 01-03-2008, 09:58 PM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
if you put in an analog tach into digital cluster, you'll need to trim the tach piece a little bit.
WheelsDirty
Old 01-03-2008, 10:04 PM   #6
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
I have both HUD custers
the tch peices require NO trimming to fit.
the sohc speedo will NOT work with the dohc engine, a resistor has to be installed somewheres to make it work ( im still trying to figure that out )
and vice versa, the tach and speedo signals are different on the HUD clusters, KA to SR or KA to KA swaps ( e to de )
its easier to try to find a dohc HUD cluster from a wrecker and put it n with your doihc engine, make sure you get the harness for the cluster though. if you dont already have a HUD harness.
Big Zee is offline   Reply With Quote
Old 01-03-2008, 10:11 PM   #7
stinky_180
stinky_180's Avatar
Trader Rating: (26)
when i found a SOHC digital cluster in the junk yard the tach did not work with the DE motor. i went ahead and tried to put the DOHC tach into the digital cluster but then it wouldn't sit right because one or two of the corners touches part of the cluster housing. the solution was to trim a very small piece of it.
WheelsDirty
Old 01-03-2008, 10:24 PM   #8
koolcat
so will the sohc digital cluster work by just changing the tach from the analog dohc engine and trimming it or whatnot or like Big_Zee said, the sohc speedo will not work with the dohc engine??? im still lost. Just tell me if i get this digital cluster from the sohc engine will it works or not by just changing the tach from my stock cluster asap? Im about to buy it cause the guy have a lot of ppl wanting it
Old 01-03-2008, 10:52 PM   #9
stinky_180
stinky_180's Avatar
Trader Rating: (26)
if you have a sohc you need a sohc tach, and vice versa
the speedometer does not matter, even if its sohc and dohc.
WheelsDirty
Old 01-04-2008, 01:51 AM   #10
koolcat
so what? do not buy the sohc digital cluster for my dohc engine ryte????
Old 01-06-2008, 01:54 PM   #11
Big Zee
Big Zee's Avatar
if you can get a dohc cluster it would be easier, then you can pawn one off the sohc one.
or you an build the hybred cluster it should work, but I dont see having to trim any peices...I didnt on mine ? unless its a S14 tach maybe ?
Old 01-06-2008, 02:02 PM   #12
johngriff
johngriff's Avatar
Swap the tach's. That is all that is specific.
Keep the matching pigtails against the clusters.
All other info in this thread is WRONG.
I AM NEG REPPING YOU.
[email protected]
