Old 01-08-2008, 04:34 PM   #1
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
drifting a vert
i recently aquired a vert to relpace my stolen coupe and i was wondering if there will be an issue with tracking it. Are there any special rules that a convertible has to follow. i did a quick search and found nothing. thanks for your time guys.
georgesal is offline   Reply With Quote
Old 01-08-2008, 04:36 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Get a good cage.
Not only because there is no top on the car, but because 'Verts are over flexy.
Don't know if it's a "Rule", but it is a good idea.
Old 01-08-2008, 04:54 PM   #3
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
^what he said. Make sure you are safe in the car. and then do the other basics for drifting.
KA-T_240 is offline   Reply With Quote
Old 01-08-2008, 04:55 PM   #4
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
No you can't drift verts.
If you look inside the glove compartment box there's a booklet hidden in the upper right hand corner which states that.
Duh....
I can't believe you didn't know.
Old 01-08-2008, 04:59 PM   #5
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
I don't know if they require roll bars for drift days (practices), but if you are doing any track events, drifting @ horsethief, etc, you will need one.
Here's one that will work for basically all events requiring 4-pt roll bar:
DavisFAb S13 240sx Convertible Roll Bar Kit
^ The description & pics are old. The kit is now TIG welded (in picture it is MIG welded) & the base plates are cut better.
In my car - most recent pic I have:
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 01-08-2008, 05:38 PM   #6
georgesal
georgesal's Avatar
thanks i was just looking at your posting on nico. did that you feel a difference in the how the car felt before and after. was there less body roll,
Old 01-08-2008, 05:44 PM   #7
brokeAs240sx
Trader Rating: (40)
Significant difference felt in the rear half of the car. Made driving it before feel like spaghetti, haha.
Even before the roll bar, though, the vert is suprisingly stiff (during grip at least). I also autox'd an s13 coupe before this & have ridden in all sorts of s chassis setups; the vert feels just about as solid (especially w/ rollbar), just a lot heavier, hee hee.
I'll be attending the scca autocross this weekend @ Fontana if you'd like to ride along in the car. You can pm me. Otherwise, you may want to check out the drift day going on in El Toro - do the drift or grip if you want to test out your car.
bew bews!
Old 01-08-2008, 05:53 PM   #8
georgesal
georgesal's Avatar
man i'd love to be there but i have to work. why can it be all play and no work.
Old 01-08-2008, 05:54 PM   #9
Sonic Motor
www.SonicMotor.com
Sonic Motor's Avatar
Trader Rating: (113)
Sonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfectionSonic Motor is close to perfection
Feedback Score: 113 reviews
Send a message via AIM to Sonic Motor
you should get a rollcage for it if you wanna drift...
But you need at least a roll bar to run most courses!
You can come our events with just a roll bar
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK )
Sonic Motor is offline   Reply With Quote
Old 01-08-2008, 06:19 PM   #10
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
i know a few BMW roadster/verts had additional chassis bracing to increase chassis rigidity. the bracing was only included on these models, and not hardtops/coupes.
i never looked into it but did Nissan use a similar approach to reduce chassis flex due to the lack of a hardtop?
for more info on the BMW bracing...
http://www.turnermotorsport.com/html...RODUCT_ID=E36X
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 01-08-2008, 06:30 PM   #11
brokeAs240sx
Trader Rating: (40)
there's a ton of extra bracing (not all the added weight of vert vs coupe/hatch is bad weight). There's an FSM picture floating around somewhere that shows all of it, but basically:
- front fender brace spot welded in
- area where 2 front seat bolts mounts to and door sills reinforced
- front of rear seat area reinforced
- rear strut towers have a metal box between them (like a giant welded in strut bar)
- the area below the car on the frame rails are reinforced (front near radiator support & area where you normally put jack stands)
There's a few more spots too, but those are the ones off the top of my head.
bew bews!
Old 01-08-2008, 06:37 PM   #12
brokeAs240sx
Trader Rating: (40)
* as a side note, I don't think we can really compare a 240sx vert vs coupe to a BMW vert vs coupe.
The reason is I believe the BMW verts were built as verts from the beginning and had the additional bracing from the factory.
The 240sx vert was basically 240sx coupe shells w/ bracing added on by ASC (think that is what it's called) afterward.
bew bews!
Old 01-08-2008, 06:39 PM   #13
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
i dont see why you cant?
S13Boosts is offline   Reply With Quote
Old 01-08-2008, 09:43 PM   #14
drftwerks
all verts are doomed to fail, case they are not the one ton garage vert (even if it never gets finished)
giantroboteyes.wordpress.com/
Old 01-08-2008, 09:46 PM   #15
johngriff
johngriff's Avatar
huh? verts are gangster...
george............
[email protected]
Old 01-08-2008, 09:59 PM   #16
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
I'm a big fan of verts, after I did a cage in one, I really wanted to find one for myself to build.
Hopefully someday I'll have one. But until then I'll live my vert dreams through that car. It should be coming back soon for gussets. Gussets are key with the vert, even with the full cage, the front of the car still isn't completely tied together. I had the windsheild rubbing against the a-pillar bar when I drove that car. So it's getting some a-pillar gussets and some other good stuff.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 01-08-2008, 10:29 PM   #17
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Vert = heavy. I got rid of mine with the quickness because the difference in weight and rigidity were pissing me off....
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-09-2008, 01:02 PM   #18
Sonic Motor
www.SonicMotor.com
drifting is about style...
Nothing says Style, then drifting top down.
Just for fun, a roll bar and side bars should be enough IMO.
However, its kinda retarded to drift with full rollcage in a vert if its not for formula D or something. Like La Phantom says, its really heavy and probably not worth all the trouble. Might as well get rid of it and get a coupe or something if someone is serious abuot drifting...ppl need to stop trying to be different like Ben swartz
Old 01-09-2008, 02:06 PM   #19
Bushido
Bushido's Avatar
sucks that a rollcage ruins the look of the vert.
hmm.. anyone ever thought of adapting the rollbar that is used on some convertible cobra mustangs?
Old 01-09-2008, 02:11 PM   #20
Sonic Motor
www.SonicMotor.com
yeah exactly!! i totally agree.
Old 01-09-2008, 02:12 PM   #21
brokeAs240sx
Trader Rating: (40)
Nice! Top still open & close normally w/ that cage setup? I'm slowly heading toward that point of full cage but still want to be able to lock the top, which seems to be in the way of optimal cage tubing .
Bushido:
There were a couple guys who adapted the dual hump roll bars from miatas... however, looking @ the finished product, it looked more likely to endanger you in a rollover than protect you. Looked pretty good though.
All you'd really have to do to get "close" to that mustang style is dress up your roll bar w/ some fiberglass/plastic - of course, you'd need some fiberglass/plastic skills.
bew bews!
Old 01-09-2008, 02:48 PM   #22
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
Originally Posted by ThatGuy View Post
Get a good cage.
i think there is a rule there arent too many verts over here but Rob from touge factory drifts in a miata and from what i remember from the stack of rules they put out for having a vert is that you'll have to have it. no matter what.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 01-09-2008, 02:55 PM   #23
Wiisass
Wiisass's Avatar
Bushido:
Everything still fits with the top. It's a tight fit, but everything fits. The way the hook swings up when you're closing the top kind of twists around the bar. Being a vert, there were some compromises so everything would still function, but I don't think there was really anything major that was changed too much. The biggest problem was the thinner main hoop due to the extra chassis bracing coupled with the wider seat that was being used. So it made the door bars pretty interesting, but I love the way they came out.
There's some pics in my gallery that show the fitment with the top a little better:
http://www.theoryinpracticeengineering.com/gallery/chi/
I think if you're doing any performance driving with a vert, a full cage would be best. It's awesome driving around a car with a full cage with the top down. There isn't much more above you with a full cage than with a roll bar and you get a lot of additional stiffening from it. And with a good cage, a lot of the extra bracing can be removed and the car can come back down to normal s-chassis weight.
I really want to build one with a full cage and just get rid of the top all together. Just have it for nice days, it would make an awesome summer car, I just wouldn't want to run errands with it and leave it all open in some parking lot for too long or get caught in the rain, but other than that, it would be a lot of fun.
Tim
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Old 01-09-2008, 03:16 PM   #24
johngriff
johngriff's Avatar
You have to have a cage to tandem regardless, and that is the most fun. So everyone should have a cage anyways. Its just safer.
[email protected]
Old 01-09-2008, 03:20 PM   #25
azndoc
azndoc's Avatar
Trader Rating: (47)
Ye$ John i$ correct, it$ better to be $afe than $o$$y.
Old 01-09-2008, 03:26 PM   #26
!Zar!
!Zar!'s Avatar
That'$ a nice cage. The weld$ and fitment is $pectacular.
Props to Wii$a$$
Old 01-09-2008, 03:46 PM   #27
Wiisass
Wiisass's Avatar
Thank$ Zar. What'$ with the dollar $ign$?
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Old 01-09-2008, 03:49 PM   #28
DUFFM4N
DUFFM4N's Avatar
Trader Rating: (40)
that cage i$ ballin....plan$ to paint it or ju$t leave it a$ i$ ???
CLICK HERE FOR MY BLOG
Old 01-09-2008, 03:52 PM   #29
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
I'd $ay don't paint it. if you wanna $ee head$ turn, leave it ru$ted to $hit.
That'd look $0000 cool.
$eriou$ly. Unpainted.
SochBAT is offline   Reply With Quote
Old 01-10-2008, 03:55 PM   #30
brokeAs240sx
Trader Rating: (40)
Found the info on the bracing added on by ASC:
Originally Posted by Hijacker from forums.nicoclub.com/zerothread?id=77984
Chassis bracing. And lots of it
bew bews!
