Old 01-10-2008, 07:51 AM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
wierd problem? im stumped..
ok i was putting the car into my drive way, and letting the car warm up.. i see a little white smoke , i think nuthing of it maybe condensation.. also i hear a wierd noise. like a hi pitched squeal, kinda like a blet squeel but more hi pitched and sounded motor wise.. as i reved the car it got louder and and sound like it was moving faster..
by now the car was up to operating temp. and the white smoke was still apparent.. so i pull the car in and decided to check the plugs. lose the tension form spark plug #1 and oil comes spraying out the spark plug hole.. WTF? the rest of the cyld were fine, clyd 1 had oil in it.. but i say no blue smoke form the exhaust..
did a comp test. i got 180 across all 4.
the only thing that was not normal was that my wastegate is going so i was driving on the hi way the other night and my boost spiked to 15psi, i had good fuel tho, i was still 11.7:1 on the wide band..
now the part that stumps me i put the plug back it, start the car up and the noise and smoke is gone!. the compression is still 180 across all 4. and the car sounds healthy , idles fine...
my setup is a ka-t t4. on 8psi. ka has 113k on it..
any clue on what when on?
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 01-10-2008, 09:58 AM   #2
shmiddy
shmiddy's Avatar
thats freaking weird man. the oil literaly came "spraying" out where the spark plug went?
i fully de-volved
Old 01-10-2008, 10:20 AM   #3
turbo2nr
turbo2nr's Avatar
yea it shot up hit my hood and fell back down around my passanger shock tower..
i mean i can understand if cyld 1 was on top of compression stroke and losing out the plug relived the cyld. pressure causing the oil to shoot out.. but how did that much oil get in there.. it was like 1.5 cap fulls.
s14 kouki ka-t
Old 01-10-2008, 10:44 AM   #4
vinhnumber
vinhnumber's Avatar
vinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfectionvinhnumber is close to perfection
its probably just burning off the excess oils left in there. Maybe oil spilled in there.
Oh you be mad cuz I'm stylin' on ya!
vinhnumber is offline   Reply With Quote
Old 01-10-2008, 10:49 AM   #5
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
could have a bad piston ring and its causing blow by, also could have a bad manifold seal causing it to leak into the spark plug area..
deesz is offline   Reply With Quote
Old 01-10-2008, 11:07 AM   #6
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
my .02
Oil could have leaked from the spark plug location to valve cover circular seal area. the spark plug location acts as a reservoir if the seal is bad and when the cylinder is at tdc (under pressure) while removing th spark plug, the oil would have sprayed all over...
let5l1de is offline   Reply With Quote
Old 01-10-2008, 11:08 AM   #7
MA JasonG
MA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura aboutMA JasonG has a spectacular aura about
Send a message via AIM to MA JasonG
Originally Posted by let5l1de View Post
my .02
My thoughts exactly. +1
MA JasonG is offline   Reply With Quote
Old 01-10-2008, 11:31 AM   #8
turbo2nr
turbo2nr's Avatar
i didnt check it, but the problem never happend again, but i did change the rubber gasket like less then 7k ago..
i was thinkin i blew the ring lands but i hold compression perfectly.. so its reallly wired.. and where did the noise and white smoke come form? and why did the oil burn out while the car was idleing for like 10 m before i pulled the plugs.. didnt stumble or nuthing..
s14 kouki ka-t
Old 01-10-2008, 12:02 PM   #9
let5l1de
let5l1de's Avatar
Trader Rating: (30)
a few more situations that could have caused your simptoms resolve
1. seal could have been installed wrong (accidents happen)
2. ring lands generally do not just blow out very easy. it may be possible
3. noise may have come from a number of things. Im thinking anything that rotates other than any internal engine part. Alt, idler pullys, p.s. pump, ac clutch, fan clutch and ...
4. white smoke usually means water in the combustion chamber when exhaust condensation is ruled out.
5. as far as oil burn out, be sure the oil was in the cylinder. check the spark plug location before removing it. if you see oil, this will confirm if oil is coming from the valve cover circular gasket location. If no oil is present, proceed to pulling the spark plug and view the tip. if the tip is wet, it may be from bad valve seals and or guides, piston ring gaps just happened to line up increasing blowby. Rings do not seem to be a factor since compression was good in all cylinders..
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
