Old 01-10-2008, 02:54 PM   #1
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
5 spd ecu wont connect to harness
just finished my 5 speed swap, and am trying to get the wiring finished up. heres my problem: the auto ecu attaches just fine to the harness, but when i go to attach the 5 speed there is a stud that gets in the way of the 10 mm bolt on the harness. below is a pic. ive tried using channel locks to twist that stud out, but it seems pretty well attached. any ideas?
nep is offline   Reply With Quote
Old 01-10-2008, 04:05 PM   #2
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
just use the auto ecu...im actually running an auto ecu on my 5 speed...it actually overrides the governor so you can go as fast as your engine will go =)
bbejj123 is offline   Reply With Quote
Old 01-10-2008, 04:15 PM   #3
Snott Rocket
Snott Rocket's Avatar
Snott Rocket can only hope to improveSnott Rocket can only hope to improve
Cut the stud off, plug in the ECU and wrap some tape around everything...
I'm a product of your hate
Snott Rocket is offline   Reply With Quote
Old 01-10-2008, 05:15 PM   #4
nep
nep's Avatar
both are possibilities, thank you. i will continue running the auto ecu for the time being, if anyone has any other suggestions i would be greatful
Old 01-10-2008, 05:35 PM   #5
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
that exactly right! no limiter and may have a better fuel map. as for the pin, i would guess to remove it if at all possible.
FYI: I swapped an 97 OBD-II engine/5spd trans, harness and auto ECM into my 89 coupe. It was a PITA to convert the dash and chassis wiring to the s14 harness... stick with OBD-I (S13) KA24DE stuff if you are s13.
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
