Old 01-10-2008, 06:40 PM   #1
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
lsd identify plese.
ok i have a problem.
i think this is a nismo lsd. lookz similar from the one on courtesy.
the problem is its reallie hard to turn. on the ring gear (bigger) it says 43:12?
which is the higher one i believe.
the thing is its hard to turn.
history of it been sitting for awhile. and oil in it is reallie old. and when i cracked it open it dint even have to drain oil out.
my 2nd problem i took out the output shafts. and i forgot which side goes in which side and i dont know the tq specs of the brackets.
please help.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 01-10-2008, 06:54 PM   #2
bo2o
bo2o's Avatar
ok i found the write up with specs. but i still dotn know which output shaft goes where.
can i just use my 6 bolt shafts? the one thats on it rite now is 5 bolt.
and the casing is the vlsd from a 180sx.
^^^click^^^
Old 01-10-2008, 06:54 PM   #3
drftwerks
think nismo, cause non smooth diff outside, most nismo, trd, mazda speed, lsd have a rough outside, the real aftermarkets, most have smooth outsides
giantroboteyes.wordpress.com/
Old 01-10-2008, 10:49 PM   #4
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
shorter output goes on the left side (driver side)
Jung918 is offline   Reply With Quote
Old 01-11-2008, 12:12 AM   #5
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
where could I get nismo gt spec lsd? I heard many people got it for around $700 but I could find anywhere that sell it for 700.
4bangers is offline   Reply With Quote
Old 01-11-2008, 01:27 AM   #6
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
thats a 3:58 geared rear end . Very interesting. That rear end ratio was not used in any of the GTR's or S series chassis's. Thats like a Nissan V8 ratio or a Z31 ratio. You better have some real HP coming out of your engine or that ring pinion is going to be a dog off the line. Remember our cars stock have 4:08's.
New Video
Buy my mounts!
Old 01-11-2008, 05:10 AM   #7
Sileighty_85
Sileighty_85's Avatar
If its hard to turn make sure its shimed corectly, I had the same prob when I shipped mine home (I had to break it down) and forgot to lable the shims. once the carrier bearnig journals are tightened you should have a little bit of back lash
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-11-2008, 01:58 PM   #8
bo2o
bo2o's Avatar
it has a lil bit of back lash.
would it be hard to turn because of gearing?
its not the 3:58 gearing it says 49:12 or 43:12 cant remember. but ill check it agen.
^^^click^^^
Old 01-11-2008, 05:09 PM   #9
drift freaq
well I was going by numbers you posted lol. If its 49:12 then its a 4:08, but you have to tell us the right numbers! You initially said 43:12 which did seem odd but you said it!
Otherwise your going to get a different number lol.
you divide the larger number by the smaller number for your final drive ratio.
New Video
Buy my mounts!
Old 01-11-2008, 10:05 PM   #10
bo2o
bo2o's Avatar
so is it harder to turn if i have the 4:08????\
forshure its the vlsd housing from a jdm s13 it has 5 bolt axles too
^^^click^^^
Old 01-11-2008, 11:04 PM   #11
drift freaq
Basically LSD's are just a bitch to rotate by hand. lol
New Video
Buy my mounts!
