Old 01-11-2008, 03:38 PM   #1
SR20n00b
SR20n00b will become famous soon enoughSR20n00b will become famous soon enoughSR20n00b will become famous soon enough
drag slicks
what is a good size for slicks? think about putting them on stock or cheap rims. im still 4 lug. also if it helps i have 215/35/18 in the front
SR20n00b is offline   Reply With Quote
Old 01-11-2008, 03:49 PM   #2
S13FREEAAK
Drifterella
S13FREEAAK's Avatar
S13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfectionS13FREEAAK is close to perfection
For a drag radial, alot of people have run 235/60/15.
Full blown slick would be around 26x8-15 or around there, depending on what you want your gearing at.
S13FREEAAK is offline   Reply With Quote
Old 01-11-2008, 04:30 PM   #3
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
if your going to get slicks, more sidewall = better. Try to stick to a 15 or 16 unless you are going to run a 28 or 30 inch tall tire, which you dont really need to do. How wide of a slick you need depends on how much power you are making.
I have 26x10 for 15s for my car. And then look into weld drag lites. 15x8 with 4 1/2 backspacing.
KA-T_240 is offline   Reply With Quote
Old 01-11-2008, 04:34 PM   #4
SR20n00b
thanks for the info man.
I have 265 rwhp prolly will just throw slicks on stockers since it wont matter with my 18s in front.
so with that what would u suggest for my power on stockers?
Old 01-11-2008, 04:41 PM   #5
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
thats what i run 275/15 nitto drag radials. works great for 300 hp. u might need a new clutch tho. it tore up my stage 3 clutch.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 01-11-2008, 04:47 PM   #6
SR20n00b
erm yeah.. im saving right now to get this...
http://www.eatmotorsports.com/products/?id=5121
edit, btw i have a 180sx rear end if that makes a difference.
Old 01-11-2008, 04:48 PM   #7
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
26x8.5x15 mickey Thompson slicks
they fit great on rotas
i cut 1.5 60's with them on my car
^^^^ about the os giken clutch, you should try and look for a used one because the discs are replaceable and itll never go bad
sr20boostn20 is offline   Reply With Quote
Old 01-11-2008, 06:26 PM   #8
KA-T_240
Those are my slicks Next to 255/40/15. With 265whp a 8 inch slick will do just fine for you. Putting the stockers back on the front will help, less rotational mass that the car has to push.
