SR lifter noise
i finished my SR20DET swap and i started my car and my valves are very very loud, is that normal?? i drove it twice around the block and i thought that maybe once oil got into the valves it would go away but it didnt yet. Whats going on with that? Is that a normal thing for SR's? Please help..
did you take the head apart? there are shims on the rocker arms that adjust valve clearance, if they are out of spec they will cause noise.
R34 NEO POWER |
put them in oil and find some thing thin enough to bleed the lifters...the lifters should compress when you bleed them...there should be a hole on top the lifter and i think there was a smaller hole in that hole and then the ball bearing. So look for the thinest thing you can find to bleed them
#7 | |
![]() Join Date: Nov 2006
I hope this helps, go about halfway down CLICK HERE
![]() $pending dead pre$ident$ J@CK@TT@CK! |
#9 | |
They do it hydraulically. Oil pressure pushes up on the lifter and keeps the rocker in constant contact with the cam.
Sometimes injectors can make a ticking noise that sounds like the valvetrain. Although it's usually not very loud. Anyway bleeding the lifters is not very difficult. Just a little time consuming. The write-up in this thread is good.
thats exactly what i was thinking at first about the injectors but yea like you said anyways bleeding the lifters is not hard....the link that tknbkthrsdy4anfg gave is good help
#12 | |
Thanks guys, I had to do it twice because I turned the motor over.
oops. Anyways pump those lil buggers!
