Old 01-14-2008, 08:35 AM   #1
S13_SideWayz
S13_SideWayz's Avatar
S13_SideWayz can only hope to improve
KA heating up problem.
ok well am having a huge issue with my car heating up..i recently swapped my 91 ka for a 97.. it worked fine until it started to heat up.. hours later.. my uncle changed the thermostat.. and i thought he put it in wrong due to reading high temp. but with water on the radiator and little tank for radiator.. today i took it out to the bank and back.. still heated up.. but when i opened the hood.. the little tank was FULL!! up to the top.. when it was normally a little below max.. and read high temp. could this be a block problem? pushing water back and then heating up? lmk ! plz!!! ty
S13_SideWayz is offline   Reply With Quote
Old 01-14-2008, 08:48 AM   #2
Ninjabread
Ninjabread's Avatar
Well, could be an air pocket in your coolant system. Did you guys bleed it properly?
Worse case scenario is your head gasket. But look for any leaks, and try bleeding it again.
The easiest way is to drive the front of the car up on blocks, or jack it up to have the motor at a backward angle. Make sure you turn the heat in your car all the way up. Make sure your overflow tank has some coolant in it. Now, open rad cap, start the car, wait until it heats up and the coolant starts to flow. At some point it will start going up, so put your rad cap on and let it run for another 5 minutes.
Turn it off and let it cool down for 15 minutes. Open the rad cap, top off the fluid and repeat.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 01-14-2008, 09:53 AM   #3
S13_SideWayz
am def. gonna have to try that ... but they told me if it was the head gasket i would see white smoke coming out and well none wat so ever.. they also told me to take out the thermostat and run it without it.. mite now be opening rite since its new..and if isnt that then to replace the water pump.. but ty i will def. take that into consideration.
Old 01-14-2008, 11:47 AM   #4
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
As silly as it sounds...did you install the thermo with the jiggle valve up? Some people forget to do that.
-Retired
98s14inaz is offline   Reply With Quote
Old 01-14-2008, 01:22 PM   #5
Ninjabread
Ninjabread's Avatar
Thats another possibility, that happened to me before.
613DriftWerks.ca
Old 01-14-2008, 01:27 PM   #6
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Maybe timing sucks?
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 01-14-2008, 03:04 PM   #7
S13_SideWayz
how would that explain the fluid coming back?
Old 01-14-2008, 03:10 PM   #8
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
I ran without a thermo before and it just seemed to create alot of pressure and still overheated sometimes. Just keep bleeding it, test your thermostat before you put it in also.
it's a RUCKUS life
Xandy Boosts is offline   Reply With Quote
Old 01-14-2008, 03:13 PM   #9
Irukandji
Check for air pockets, make sure the thermostat is working properly, and check the waterpump while you're at it.
Irukandji is offline   Reply With Quote
Old 01-14-2008, 03:24 PM   #10
rlpinoy
rlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choices
maybe your waterpump is done. mine overheated when the car was off but drove fine. also whenever you do anything to your radiator water you must bleed the system or it will fuck with you.bleed the system first and see if anything changes if not check the thermostat he installed and change the water pump while you are at it.
FS Exhaust, Q45 ignitors, & MORE!
rlpinoy is offline   Reply With Quote
Old 01-14-2008, 04:18 PM   #11
S13_SideWayz
can some one post a pic of how the thermostat should be?also can this be caused by the returning hose? meaning the water is not coming back to the radiator due to it been it blocked or something? so then the top hose cant feed more water so it returns it to the reservoir tank? thanx
