![]() Join Date: Feb 2002
here ya go, this is in the FAQ section under the thread for Free/Cheap Mods:Sleepy Eyes (s13)
1. Make sure headlamps are off and in the "closed" position. 2. Get down on your back and look up through the large opening in the lower front bumper. 3. Look directly under the left and right headlamps and find their electronic plugs. 4. Now while you are down there, you can reach through the large opening and unplug the electronic plugs left and right. You must unplug these in order to adjust the headlamp motors manually. 5. Now get off the ground and pop your hood. You should see a headlamp motor next to each of the headlamps. Looks like a single prong. 6. Pull the cap off each headlamp motor. Now you may manually adjust the headlamp angle at any variable by turning the knob. Make sure that both headlamp motors are evenly adjusted. 7. Now turn your headlamps in the "on" position. Notice the motors dont move and the headlamps simply light up. Viola, instant "sleepy look." **Now in order to get the headlamps in its original position you have to manually adjust the headlamps in the "closed" position via the motor. Then plug the wiring back together. And btw, it is usually called Sleepy Eye. Lazy eye is if you have a medical problem with you eyes, lol. Or you can buy a Pivot Headlamp controller, it's a waste of $100 IMHO. I just did it the cheap way above. ~Ian |
![]() Join Date: Oct 2002
Here....this is a little more
time consuming in the beginning....but once done...no more messing around.
http://www.geocities.com/velocityyok...180lights.html Enjoy. DIY. Just be sure you double check your wires. Not 100% sure if the USDM wiring is the same color codes.
Marc - Yokohama, Japan ![]() |
how can i check the wires?
92 240sx FB: 5 Speed baby Champagne NOT gold ![]() the reason i got the s13 over the s14 is def. bc it had automatic seat belts .... www.fungbodyboarding.com ... check it out |
Pull the switch....
If the wires are the same, you should be good to go.
A buddy of mine did his first. He checked them with a volt meter. I'll have to get ahold of him and ask him what clued him into which wire to cut. Give me a day or so.
aight man thanks ...
i want my headlights to lay flat when off and come half up when on. i guess ill have to get Pivot Headlamp controller or the replacement lights from autoimaging.
boostin through a neighborhood near you! |
my ghetto way to make sleepy eyes is here:
http://www.zilvia.net/f/showthread.p...760#post314760 |
