Old 01-11-2003, 10:28 PM   #1
mixedwell
mixedwell is an unknown quantity at this point
Send a message via AIM to mixedwell
Wink eclipse SMIC in sr20det
hey kids. a good point was brought up to me. how good is an eclipse SMIC (side mount intercooler) for the sr20det and how much boost will it be good for? they are very very cheap!
holla!
mixedwell
im so happy. now i can use my s13 SR20!
silvia... my love ::
mixedwell is offline   Reply With Quote
Old 01-11-2003, 10:33 PM   #2
Mark & Irena
Guest
Posts: n/a
From what I know, they're just as small as the OEM SMIC for the SR20. Starion ICs are FMs and are fairly cheap. You should consider one of those.
S13Grl
Old 01-12-2003, 12:48 AM   #3
240racer
240racer's Avatar
240racer is an unknown quantity at this point
the stock smic on the DSM is almost the same size as the stock SR20 smic. They flow fine, but don't have the ability to cool very well since they have such small surface area. I am using 2 of them welded together with my own end caps and my buddy is is using 3 of them welded together on his MKIII. He is running 16psi and 400rwhp, so I guess they are good. the main advantage of a fmic is that it is mounted with more direct airflow, so it can cool better, not to mention that they are usually larger and have more channels for the charge air to flow through which results in less pressure drop. Also, there is no reason for us not to run a fmic since the turbo is on the opposite side of the engine then the exhaust.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
240racer is offline   Reply With Quote
Old 01-12-2003, 08:20 PM   #4
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
my friend drives a DSM and hes using my other friends SM, off an MKIV supra. its like 2-3 inches thicker than the OEM dsm one. i dont know any numbers. ill get back to you on that.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 01-12-2003, 08:49 PM   #5
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Yea... it's ok, but not very smart financially.
Also.. whatever you do, DO NOT use a MK III supra intercooler. They suck. 60% efficiency and 3psi pressure drop at 7.3psi.
Sorry... response brought up due to someone mentioning supras in general.
-Jeff
Whatup?
Old 01-12-2003, 09:40 PM   #6
95Blue240sx
i think the best thing to do, is just wait and get a FMIC, unless you are staying stock. buying SMIC from other cars arent worth the trouble IMHO
Old 01-12-2003, 11:53 PM   #7
mixedwell
yeah guys you know... im just gonna buy a stock DSM SMIC and use it for a while. i know that a FMIC is the good deal but for now when i have no ends, and i really want to use the motor, i think that the SMIC is good- for now.
on another note.... i've seen some skylines that used SMICs and FMIC together. withouth weilding, could i use 2 SMICs and how effective would this be? holla
mixedwell
ps- about how much PSI would a SMIC be good foor? 10 psi?
Old 01-13-2003, 01:29 AM   #8
240racer
240racer's Avatar
there isn't an amount of boost that an intercooler is good for. It's the turbo that determines how much boost is good for it. Any intercooler will work with 10psi, some just might cool the air more then others, but both work just fine.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
Old 01-15-2003, 01:39 PM   #9
jdmhatch
jdmhatch is an unknown quantity at this point
I got a crazy idea. Why dont you just get the SMIC for the sr20?
There are a few on a couple of forums and one on ebay right now.
Sorry about that, i didnt realize i was still a newbie. ****!!!
jdmhatch is offline   Reply With Quote
