![]() Join Date: Dec 2006
![]() ![]() Feedback Score: 1 reviews
![]() wondering has anyone used one of em. i came into a space issue that I dont real comfortable w/. nor do I feel its safe to shim the master cyl, causing the drivers side of the motor and then placing a heat shield in. honestly i drive to aggressive to even entertain that thought.
~skott ![]() t304e down pipe flange and master a lil too cozy. ![]() Last edited by Jus Skott; 01-29-2008 at 09:06 AM.. Reason: wrong link to pic |
This is a picture of a pre-built manifold, which has plenty of clearance to the master cylinder from the turbine housing.
www.nissanroadracing.com |
![]() Join Date: May 2003
Is you car automatic, or does it have ABS? If so, it will have a thicker-than-the-5-speed-version brake booster.
If not, and it's just a normal 5-speed car..then you have a manifold that someone welded with placement for a smaller turbine, or an on-center housing (is it a T4 turbine?). - Brian
www.KA24DEvelopment.com |
sorry everyone. i fail sometimes at making myself clear. the manifold i has was something like an ss auto chrome. hence why i was having the space issue.
![]() my Q was in concern w. the JGS manifolds. i was wondering was there any cons to the JGS manifold. when the prior owner "ballinmiami" had this setup. he made 311 whp and 278 tq. in 9 psi. think that this will still allow me to get the same numbers? inquiring before i buy it. ~skott |
That is largely going to be dictated by the size of the turbo, intercooler, intake manifold, amount of timing run. There really are quite a few factors that come into play. It's not just...if I run this manifold...can I make XXX power.
the JGS mani has less flow than your tubular mani, but miles more clearance.
not to mention, if thats an ssac then you have to worry about it crackin way faster than the JGS. |
I refuse to condone use of JGS since they're obviously selling piles of parts worth 10$ at homedepot/summit/metal supply for 200$ to retards.
Stick with ebay and rough it I dunno. |
![]() Join Date: May 2007
Location: Azusa, socal baby! why do i live this way?? it must be the money!
im running this jgs manifold on my built ka-t... worked out perfect..
NismoKnights ![]() Terrorizing Honda crews since 2003 ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8 Nismokights on http://www.youtube.com/user/NismoKnights ![]() |
![]() Join Date: Aug 2005
90% of my turbo setup is JGS, frankley it rocks my face off.
Russell: Most exhaust systems are complete rip off also compared to materials + labor. Yet ppl still buy them. |
I personelly didnt buy it. Im looking to keep the same setup.
jus change the manifold and DP. tho I havnt decided on running an exhaust. open DP FTW. ![]() some of you may have seen this motor when Danny Owned it. if not here it is. ~skott http://videos.streetfire.net/categor...7900986833.htm |
![]() Join Date: Mar 2004
wowzers, russellpants. 56 reps huh?
rough it out A? I thinks JGS has the best overall option for KA-T development in the gray market yet. and here's why. .. .all IMO. any preset prebuilt manifolds or log types are very well off in the KA-T lineup, for price and durability for H.O. turbo KA's. ( or those wanting to get there?) But these types are typically displayed by/for disco potatoes (T3/T04E) so when looking at the marginal value, we see JGS up top, based truly on time and efficiency under installation, heat durability, and service convenience. and skott, I think a heatshield is always a good way to go, or heatwrap the M/C.
"GHOST" |
#14 |
It's one thing to build one for yourself for a one time thing, it's a completely different thing to produce them.
You are welcome to run a business with employee's and undercut their costs, but I wouldn't expect your prices to be much cheaper...for very long anyway. There is not a huge difference in making an equal length either as far as cost goes, but no one complains about footing the bill for that. The cost/performance ratio of the JGS manifold is very good.
#15 | |
![]() Join Date: Sep 2002
JGS FTW.
My 240 vBgarage |
#17 |
i have the JGS manifold on my 240. installation was a breeze compared to the problems i had when i was running the SSAC manifold. plus, the ssac manifold cracked after 2 events and put my DP like 1/4in away from the MC. JGS moved my turbo way forward and only thing i had to do was reverse the power steering bracket and massage it a little to put the PS reservoir where i wanted it (well that, and a new DP).
JGS ftw. great placement, easy to work on/with, and very strong.
http://www.ericisaboss.com |
#18 | |
"GHOST" |
#20 |
![]() Join Date: Aug 2006
Not that I own one, but Im in the process of buying a particular car that uses the JGS manifold and if it were to come exactly as it is but with a SSAC manifold I probably would not have bought it.
The JGS log mani is a proven and reliable design, hence the reason most OEMs use a cast log mani for spool response and longevity. For the majority of people on here with hp goals less than 500, its a stout choice and great purchase for the money.
Sold the Z, sold the S14, now I drive a G35 6MT coupe. |
#21 |
Yeah, I haven't seen anyone posting anything wrong with JGS with the exception of custom welded flanged JGS manifold.
A cast iron manifold is probably the last manifold you'd ever need, and you wouldn't have to worry about reliability. I think I might go with JGS on my KA-T if I go T3 instead of T28. |
#23 |
I think McRusselPants has JGS confused with JGY Customs...hence why he made such strongly worded comments.
JGY Customs has a horrible reputation in the 240sx community. JGS has a very good reputation in the 240sx/KA-T community. I own a JGS manifold. It's good stuff.
jollydwarf.com |
#24 | |
#25 | |
#27 |
Not sure what bumper it is. It came off the boat with it. Someone in the UK has the same one. I think its a factory option or a knock off because it says Skyline on the front of it.
#28 | |
#29 |
as requested:
![]() ![]() ![]() ![]() ![]() If someone would buy my S14, I could do the upgrades I want (since I'm only allowed one project at a time). Meh.
