Old 02-01-2008, 02:17 PM   #1
jerryk
jerryk's Avatar
jerryk is a well-known jackass
1990 240SX fluctuating idle problem
I own two 1990 240sx. Both are on the road. I have a fluctuating idle problem with one of them with 177K on the engine. It is scheduled to be my final car. I know what the idle is supposed to be a bit above 730 because my other one with 220K has a perfect idle. The fluctuating /hunting idle goes between 780 and 950 when warmed up or at a stop. Sometime it fluctuates worse then others but it never goes below780 and is always moving. I just made a trip to PA and the road mileage is, I swear 31MPG, but in the city, it ranges between 21 and 23, which is costly these days. The other car gets 25MPG in the city and 30MPG on highway. I have both cars at a mechanic and he has been swapping parts.
Air regulator
AICV
MAF meter
EGR valve
I would appreciate any ideas.
jerryk is offline   Reply With Quote
Old 02-01-2008, 02:22 PM   #2
Captain_Ron80
Captain_Ron80's Avatar
Captain_Ron80 is making a name for him/her selfCaptain_Ron80 is making a name for him/her self
Search... there is a thread on this site that explains the problem and the fix.
Captain_Ron80 is offline   Reply With Quote
Old 02-02-2008, 03:21 AM   #3
cotbu
cotbu's Avatar
check your ecu for codes!
I'm thinking CTS.
Old 02-02-2008, 02:59 PM   #4
fairladysx_s13
fairladysx_s13's Avatar
fairladysx_s13 is an unknown quantity at this point
Send a message via AIM to fairladysx_s13
Theres also an idle regulator under the throttle body on the right side. Theres a bolt that moves forward and back that u can tighten and loosen. Try to play with that and see if ur idle levels out.
New_Era Jay
fairladysx_s13 is offline   Reply With Quote
Old 02-02-2008, 03:16 PM   #5
Vernal
Vernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymore
Send a message via AIM to Vernal
i had that on my de. The timing was off though. If its a smooth idle but just high then adjust it. If it hunts and bobs then its your timing or a vacuum leak or both.
Vernal is offline   Reply With Quote
Old 02-02-2008, 04:23 PM   #6
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
ive actually had this problem for quite some time now, mine usually does this when im using a defroster. I wonder myself what might be the problem behind this. Ill have to check my timing since i havent done so in like 3 or 4 years ago.
SilviaSR20DET is offline   Reply With Quote
