Old 02-03-2008, 12:18 AM   #1
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Oil Filled in Sparkplug Hole
i put oil in my car earlier because it was low. now a couple hours later after driving and then parking it for the day i come back outside to move my car and its mis-firing like a machine gun. i go to check my spark plugs and when i pull the wires only cylinder 1 sparkplug hole is filled with so much oil i cant even see the spark plug! im going to check my valve cover gasket because im thinking it may be causing the leak. if thats not the case anyone have any ideas?
ATLspeed is offline   Reply With Quote
Old 02-03-2008, 12:20 AM   #2
brewster240
brewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond repute
Send a message via AIM to brewster240
valve cover gasket leaking, or you spilled oil down there.
worse case, cracked head. unlikely.
brewster240 is offline   Reply With Quote
Old 02-03-2008, 12:21 AM   #3
91silvia
91silvia's Avatar
91silvia will become famous soon enough91silvia will become famous soon enough91silvia will become famous soon enough91silvia will become famous soon enough
Send a message via AIM to 91silvia
it's most likely your spark plug tube seals leaking. I'm not sure what motor you have but sometimes they are part of the valve cover seal, sometimes not. Just pull the valve cover and replace the four circular seals around the spark plug tube holes and replace the valve cover while you're at it.
91silvia is offline   Reply With Quote
Old 02-03-2008, 12:32 AM   #4
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
most likely spark plugs tube seals.
180sx_Drifter is offline   Reply With Quote
Old 02-03-2008, 01:33 AM   #5
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
there is a sparkplug gasket that you usually change with the valvecover gasket.
reccakun08 is offline   Reply With Quote
Old 02-03-2008, 01:59 AM   #6
hashiriya13
hashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nicehashiriya13 is just really nice
+1
I just found my #1 full and #4 not far behind. the plug hole gaskets were hard as a rock
MY CAR IS MY CAR, YOU DON'T LIKE I DON'T GIVE A SHIT
If You are in need of stuff from Japan I can Help you out. Small stuff only, shoot me a PM.
If You have bought or buy from me I finally have a review thread CLICK HERE
hashiriya13 is offline   Reply With Quote
