Old 02-08-2008, 11:50 AM   #1
Lurkable
Lurkable will become famous soon enoughLurkable will become famous soon enoughLurkable will become famous soon enoughLurkable will become famous soon enough
Send a message via AIM to Lurkable
s14 Hypothetical: cross-threaded spark plugs
How serious a problem could this be? I've recently been having an oil-leak into my spark plug tubes. Only a little in 2,3,4, but a serious amount in #1. And the other day, the connector for the spark plug wire in #1 popped off, presumably due to nasty oil build up making everything slick and greasy in there. So what, big deal right? Clean out the oil, get a new gasket...
But I noticed when I try to screw or unscrew that one spark plug, it feels like it is cross-threaded, whereas the other 3 screw out just fine. If #1 is cross-threaded, am I totally screwed? Maybe the oil was leaking down the threads of the spark plug? I don't know, I've never dealt with this kind of problem before. Any insight is appreciated. Oh yeah, it's a stock '95 KA.
Rim: n. The circular outer part of a wheel, furthest from the axle.
Rim: n. A circular metal structure around which a wheel tire is fitted.
Wheel: n. A solid disk or a rigid circular ring connected by spokes to a hub, designed to turn around an axle passed through the center.
Lurkable is offline   Reply With Quote
Old 02-08-2008, 12:21 PM   #2
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
timesert.... pain in the ass.
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
Old 02-08-2008, 12:45 PM   #3
Lurkable
Wow, looks like a pain in the ass. At least there's something out there though.
Old 02-08-2008, 12:53 PM   #4
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
find out what the threads are on the spark plug, and run a thread chaser through the head. It would help smooth out the threads a little, and prevent you from doing any further damage by threading it in wrong. But depending on the damage to the threads....it might not solve all your problems
96Turbo is offline   Reply With Quote
Old 02-08-2008, 01:01 PM   #5
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
If it has to be rethreaded, you're in for a treat lol. I have no idea how one would go about putting a threaded insert in the head without getting shavings in the cylinder, or removing the head to do so.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 02-08-2008, 01:16 PM   #6
kdashy
kdashy's Avatar
kdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfection
Send a message via AIM to kdashy
You can put grease on the chaser so the shavings will stick, or buy a small hose attachment for a vacuum cleaner.
kdashy is offline   Reply With Quote
Old 02-08-2008, 01:18 PM   #7
Howard92884
Howard92884's Avatar
Howard92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond reputeHoward92884 has a reputation beyond repute
Send a message via Yahoo to Howard92884
You might have to invest in a tap and die kit.
Howard92884 is offline   Reply With Quote
Old 02-08-2008, 01:19 PM   #8
highoctane
highoctane is on a distinguished road
Maybe pressurize the intake side on the intake stroke for that particular cylinder. Air will keep on blowing out of the of spark plug hole while you are working on it, so whatever is being cut by the chaser will get pushed out by the air.
I've never done it, but just an idea.
highoctane is offline   Reply With Quote
Old 02-08-2008, 01:22 PM   #9
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
+1 for that, thread chaser and grease...
boogerlovers is offline   Reply With Quote
Old 02-08-2008, 01:24 PM   #10
Risu2112
Risu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura aboutRisu2112 has a spectacular aura about
This happened on my 1990 ka24de 2 months ago while trying to change the plugs... I was able to change #2 and #3 but 1 and 4 I couldn't get out without stripping the head.
It was very frustrating, instead of fixing the problem I left that shit in the garage and just moved up my LS1 swap 2 months sooner so I could have the car back!
If you decide to rethread that definitely remove the head to do so or you're gonna eat metal shavings all up ons your internals, Or see if you can just pick up a dirt cheap used/reman head and just switch it out, that actually might be much less work and not a big difference on the pocketbook. KA parts are cheap.
Edit: actually yeah the grease idea isn't to bad either (just read it) Be careful though if you go that way!
Risu2112 is offline   Reply With Quote
Old 02-08-2008, 01:46 PM   #11
LA_phantom_240
Hmm... damn good idea!
Old 02-08-2008, 02:00 PM   #12
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
As for the oil leaking into the plugs, check the round rubber gaskets that go around them. replace those and see if your problem persists.
or you can silicone them
sr20boostn20 is offline   Reply With Quote
