Old 02-08-2008, 03:31 PM   #1
Tricky1980
Tricky1980 is an unknown quantity at this point
Send a message via AIM to Tricky1980
ignition issues
its been a while since ive posted(nothign wrong with car lately) but now i have power to everything.. but not a single click when i got o start the car.... windows.. wipers.. it all works.. but i turn the key to start and NOTHING... it did this the other day and then i was like huh.. got out popped hood.. sat back down and it started.. now its done it again and no magical cure... is it starter stuck? or? imjust looking for some ideas to start tinkering with..
thanks guys
JaY
Tricky1980 is offline   Reply With Quote
Old 02-08-2008, 03:54 PM   #2
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
have you tried to hit the starter with a hammer, or checked the wiring on the starter?
my last 3 starters that went bad were all spinning, just not popping out into the fly wheel.
sr20boostn20 is offline   Reply With Quote
Old 02-08-2008, 04:09 PM   #3
g6civcx
g6civcx's Avatar
I don't know if this applies to you, but relays and solenoids have been known to fail intermittently in hot weather. When they cool down, they work again.
In your case I would check the starter solenoid or any loose wiring to the starter and starter solenoid.
If all of your wiring is good, I would suspect either the ignition switch itself or some part of the starter. The ignition switch is easier to test so I would try that first.
Disconnect the negative terminal of the battery, pull off the steering column cover, disconnect the ignition switch harness, and use a multimeter to measure for continuity between the power pin and the starter pin with someone holding the key to ST. Check FSM for specific pin location.
Sometimes jiggling the ignition switch will make it work again. If everything is good then pull the starter and get it tested.
Old 02-08-2008, 04:54 PM   #4
Tricky1980
thanks guys as soon as the snow melts ill dig under the ca and try figuring it out.. thanks for quick replies....
JaY
Old 02-09-2008, 07:20 AM   #5
karmakaze
karmakaze has a little shameless behavior in the past
JaY
the ground on the starter can pop off pretty easily. it is just a glorified spade connector. that would be the first thing i would check.
karmakaze is offline   Reply With Quote
Old 02-09-2008, 11:32 PM   #6
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Your ignition switch has an electrical connector on the opposite side of where you insert the key into the ignition. That electrical connector has several positions on it - LOCK / OFF / ACC / ON / START. When the contacts inside the switch go bad, (usually on the START position), the switch is no longer able to send current to the starter, hence the reason why your car doesnt' want to start.
Remove the cover to your steering column & check the electrical connector on the opposite side of the ignition switch. Link to picture attached.
http://tinyurl.com/yvzs5o
Use a volt/ohm meter and/or continuity tester to make sure the electrical conector is working in ALL positions. It's easier to check / test &/or replace this part at $35 bucks than it is to replace the starter. Chances are the electrical connector on the ignition switch is bad & NOT your starter.
Anyhow, hope this helps.
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
