Old 02-10-2008, 06:13 PM   #1
Hooorahh!
Hooorahh!'s Avatar
Hooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfectionHooorahh! is close to perfection
Send a message via AIM to Hooorahh! Send a message via Yahoo to Hooorahh!
help with my brakes please ! ! !
k so i have z32 brakes they were grabing great ...
one day my rear tire went flat so my front breakes weren't grabbing ...
so i put air and my brakes grab again ...
now all of a sudden my brakes dont Grab at all ...
i checked for break fluid and its full
i tried bleeding the brakes and nothing comes out ... ( no brake fluid)
i took the line off the one that connects to the actuall brake its self and stepped on the pedal and the fluid did come out ...
any ideas?
Hooorahh! is offline   Reply With Quote
Old 02-10-2008, 06:45 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
You bled the brakes in order - driver rear, passenger rear, passenger, driver - and no fluid came out of all of them or just one? Locked piston?
Old 02-10-2008, 08:05 PM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
are you bleeding your brakes by yourself and they won't gravity bleed? or even with someone opening the bleeder screw and the other person pushing the pedal down, still no fluid comes out?
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 02-11-2008, 09:11 AM   #4
Hooorahh!
Hooorahh!'s Avatar
i bleed them only the front brakes thats it ..
and im haveing my brother pump the brakes then i lossen the screw and nothing comes out at all
Old 02-11-2008, 09:12 AM   #5
ziptiedae86
ziptiedae86's Avatar
ziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfection
Do you have abs? If so you need to disconnect the plug or remove the negative battery terminal prior to bleeding
ziptiedae86 is offline   Reply With Quote
Old 02-11-2008, 12:30 PM   #6
g6civcx
g6civcx's Avatar
Read up on how hydraulic brakes work and how to properly service them.
Then go read the BR section in the FSM. Inspect all the lines and calipers. Then bleed as per the FSM. I would go around at least 3 times to make sure you pull out all of the air.
If still nothing then the calipers or the master cylinder needs to be fixed.
Old 02-11-2008, 03:53 PM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You have to bleed a WHOLE system of brakes when you bleed them...
Everything is connected.
Start from:
driver rear
passenger rear
passenger front
driver front
Repeat in that order.
Did you change the BMC?
Old 02-12-2008, 08:34 AM   #8
Hooorahh!
Hooorahh!'s Avatar
no i didnt change the bmc .... ...
k so my car is a rhd does that mean i start from the opposite side ... well still from driver side .. but rhd side correct ?
Old 02-12-2008, 09:29 AM   #9
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
No? LOL, I have no idea. Unless they routed the lines differently on RHD cars.
Old 02-12-2008, 09:38 AM   #10
Dream240
Dream240's Avatar
So you have NO fluid from ANY lines when you try the 2-man bleeder technique? And you have fluid in reservior? Sounds like you have a clog in either a line or the BMC. How's the pedal feel? Is it super stiff or super soft? Does it even return? If you break the lines at the BMC do you get fluid coming out of the BMC ports and the open brake lines?
Old 02-12-2008, 06:24 PM   #11
Hooorahh!
Hooorahh!'s Avatar
yeah there is fluid that comes out if i discconect the line from the caliper ... hmmmm i think im gonna have to pay someone to fix em .... ahhhh just when i was gonna buy a bbk
Old 02-12-2008, 09:17 PM   #12
s13.dark1
s13.dark1's Avatar
s13.dark1 is making a name for him/her selfs13.dark1 is making a name for him/her self
lol thats sucks o well.
s13.dark1 is offline   Reply With Quote
Old 02-13-2008, 02:57 AM   #13
IRN
IRN's Avatar
IRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really niceIRN is just really nice
did your pedal feel change? honey glazed?
IRN is offline   Reply With Quote
Old 02-13-2008, 08:22 AM   #14
Hooorahh!
Hooorahh!'s Avatar
yeah the pedal goes all the way down kinda soft ...
Old 02-13-2008, 12:12 PM   #15
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
sounds like either ur bmc or brake booster took a crap on ya
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 02-13-2008, 12:15 PM   #16
Dream240
Dream240's Avatar
No, it's definitely not the booster, cause then it would be SUPER stiff. If you've got a squishy pedal then you've either got air in the lines, or maybe you've got a leak in your system that you haven't found yet. A loose line or loose bleeder screw? Is this car ABS?
Have you tried removing the brake line from the caliper and pressing the brake pedal? Does fluid come out? If it shoots out like it shoudl then you've got a faulty caliper. If no fluid comes out then work your way up the lines until you find where the fluid is not flowing from.
Old 02-13-2008, 07:11 PM   #17
Sileighty_85
Sileighty_85's Avatar
I had the same prob. My rear claipers locked up, replaced them but when I was bleeding them I wasnt getting any fluid out. If I cracked a hard line I would get fluid.
Long story short Replaced BMC everything worked perfect.
If you got the Z32's Front and Rear, TheNismoShop.com has a BMC for the 240 with the correct Brake Bias for the Z32's on the 240SX ($130) G/L
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
