Old 02-15-2008, 01:29 PM   #1
sofo259
sofo259's Avatar
sofo259 is an unknown quantity at this point
HICAS rear sway bar ??
i am about to obtain a rear sway bar from a hicas s13..
i have heard these sway bars are bigger than a stock non hicas s13 is..
anyone else know ??
i searched this, but found nothing
sofo259 is offline   Reply With Quote
Old 02-15-2008, 03:45 PM   #2
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Stock S13 rear sway bar diameter: 15mm
HICAS S13 rear sway bar diameter: 21mm
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 02-15-2008, 04:40 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
I have seen 17mm stock s-13 rear sways as well. One thing to keep in mind is the the stock 15 or 17mm bar is solid, the 21mm hicas bar is hollow. I personally ran a hicas rear sway on my s-13 with my stock 25mm front bar (most s-13's have 24mm front bars) and I noticed a pretty large difference in the rear roll stiffness. It really isn't a HUGE upgrade, but it is definitely worth the $60 to buy the hicas bar (I REALLY hope you aren't paying more than that). The only problem with the hicas rear sway is that it is hard to find urethane d-bushings for it. The front sway bar bushings from a z (I forget what model and year exactly) will work. Or you can drill out the urethane bushings for an s-13 with a 7/8 drill bit, I ran that set-up for a while.
Old 02-19-2008, 06:39 AM   #4
sofo259
sofo259's Avatar
naa im getting the bar for free..
