Old 02-18-2008, 01:35 PM   #1
k-os
k-os has a spectacular aura aboutk-os has a spectacular aura aboutk-os has a spectacular aura aboutk-os has a spectacular aura aboutk-os has a spectacular aura aboutk-os has a spectacular aura about
Front Coilovers hitting 17 x 9 Fn's
i have a set of tein HA's on my car
running 17 x 9 +20 Fn's on the car.
the fronts are hitting the coilover
im just getting into fitting wheels and working with suspension and everything.
what can i do to fix it?
spacers?
alignment?
k-os is offline   Reply With Quote
Old 02-18-2008, 01:43 PM   #2
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
more specific? your rim is hitting or the tire? if its the tire you can always run a smaller tire. or if youre not into that youre going to have to run spacers. cant really tell you how big of a spacer to run cause i dont know how close it is. you should really check out the wheel fitment thread also..
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 02-18-2008, 01:47 PM   #3
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
Its got to be the tire, because 17x9 +20's clear coilovers all day.
What size tire are you running? Something wider than 235/40's? I know they clear with a 17x9 +20.
whiterps13 is offline   Reply With Quote
Old 02-18-2008, 01:49 PM   #4
LB.Motoring
LB.Motoring's Avatar
Yeah,
Its possible to hit coilover with that size.
its just around that range that makes breaks front fitment, its different with different coilovers...
Just get a small 5mm spacer (slip on)
you should be all gravy.
Robby Leuer
Old 02-18-2008, 01:52 PM   #5
k-os
im running 235/40's
the rim is we took both fronts off and you can til where the inside of the rim is hitting right where the inside tire and rim meet.
they were on my friends fastback with stances and fit perfectly.
its just wierd that they hit on my car.
ima just get a set of 5mm spacers then.
Old 02-18-2008, 01:56 PM   #6
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Loosen the nut/bolts where the coilover attaches to the spindle...
Pull the wheel hub towards you and tighten the spindle nut/bolts now...
That will give you just the clearance you need...
I've got the same setup...
Nikeboy355 is offline   Reply With Quote
Old 02-18-2008, 01:58 PM   #7
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
u need like a 3mm spacer my friend had the same problem.
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 02-18-2008, 01:58 PM   #8
JohnJohn86
JohnJohn86's Avatar
JohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura aboutJohnJohn86 has a spectacular aura about
You can get a little bit of adjustment with the 2 bolts on the coilovers bottom mount. Drill a bigger hole will allow you to adjust more.
JohnJohn86 is offline   Reply With Quote
Old 02-18-2008, 02:00 PM   #9
LB.Motoring
but if you do that,
You need to make damn sure it doesnt walk back in and catch...
I think for you since, its kinda new to you I would suggest just some 5mm's get them from like Pepboys, 10 bucks for a pair.
Robby Leuer
Old 02-18-2008, 02:05 PM   #10
SoSideways
SoSideways's Avatar
I posted in the wheel fitment thread too, but as some have said already, I have these same wheels and they fit on my car with no problems. I'm running Stance GR+'s.
I ended up running some 10mm spacers up front, so definitely no hitting anything now.
I still have an extra pair, so if you're interested PM me.
I do have to warn though, that to run these spacers, you'd need extended studs. I went with the ARP extended studs for the Camaros or whatever. It was pretty cheap through Summit Racing.
Old 02-18-2008, 05:15 PM   #11
k-os
did that but its wierd the driver side is better but the passenger side is the same lol.
just gonna end up using some 5mm spacers.
thanks guys.
Old 02-18-2008, 06:25 PM   #12
fatwired240
fatwired240 will become famous soon enoughfatwired240 will become famous soon enoughfatwired240 will become famous soon enoughfatwired240 will become famous soon enoughfatwired240 will become famous soon enough
I have Tein HA's and my fronts rub also, so I just adjusted it as far as itll go and it doesnt rub. And tighten it as hard as possible. Problem solved until spacers. or new wheels.
fatwired240 is offline   Reply With Quote
