Old 02-18-2008, 03:30 PM   #1
V8slayr
V8slayr is on the path to ruinV8slayr is on the path to ruin
SAFC2 Ques.
Let me start off by saying I've done my fair share of searching this topic, but most of the stuff I see is conflicting anyway. I am curious about the IN/OUT settings for the MAF. My setup is stock S13 SR MAF, and #63 ECU. All have I really seen people saying is that for these criteria 6 in/6 out is the way to go. From my personal experience, my car runs perfect at 5 in/5 out. When i switched it to 6/6 the car suddenly leaned out at WOT around 6k and up. (have innovated wideband, a/f went from 11.8-12:1 to 14:5 suddenly). Does anyone have a definite answer as far as the settings go. Only reason I am curious now is because I am soon to do a Z32 MAFS
V8slayr is offline   Reply With Quote
Old 02-18-2008, 04:42 PM   #2
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
5 in 5 out is for KA MAF with KA ecu
6 in 6 out is for SR MAF with SR ecu
2 in 6 out is for Z32 MAF with SR ecu
2 in 5 out is for z32 maf with KA ecu
so u get the drill
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 02-18-2008, 04:44 PM   #3
gunluvS14
gunluvS14's Avatar
another question, which turbo and boost level u are running?
stock SR MAF can be max out around 10-12psig, when its maxed out, anything more than 5v output from the maf will be un-registed air - lean
Old 02-18-2008, 05:34 PM   #4
V8slayr
S14 T28 at 10 -12psi. I think I was only running 10psi at the time. What you said matches all the other info I just thought it was really weird that at 5/5 the car maintains perfect a/f ratio to redline, i've ran the T28 @ 12 psi before I installed the SAFC and never had any leaning out issues, a/f has always stayed fine. So when I switched to 6/6 and started having problems that seemed wrong to me
Old 02-19-2008, 09:11 AM   #5
V8slayr
bump, just want some more opinions/info please
