Old 01-22-2003, 06:56 AM   #1
wren240sx
wren240sx is an unknown quantity at this point
mroe cooling problems
i just got done changing the thermostat, and my gauge isnt pegged on hot anymore, but whenever im at an idle or just cruising at 30mph or slower, the temp rises slowly till its close to hot. I bled the air pressure out, and i know i have a bad radiator cap, could the cap be it? i pressure tested the system and its working fine. any ideas?
1991 240sx se
red w/ big #$* dent in it!!
5 speed
injen cai
apexi n1 dual
unorthadox pulley set
oh yeah and a blown motor
wren240sx is offline   Reply With Quote
Old 01-22-2003, 07:24 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
Eliminate all options when it comes to part replacement. Cooling system is not something you want to skimp on... More than likely it IS your bad cap.
Old 01-22-2003, 08:10 AM   #3
wren240sx
alright thanks for the info. any other ideas appreciated!
1991 240sx se
5 speed
injen cai
apexi n1 dual
Old 01-22-2003, 08:27 AM   #4
Dream240
Dream240's Avatar
How many miles do you have on the engine? Have you had a system flush done on it lately?
Check your upper and lower hoses also, cause if these are old and have some clogging in them then they will definitely cause you to heat up.
Old 01-22-2003, 08:30 AM   #5
wren240sx
i got 140,000 miles on this engine. it was flushed a year ago, book says every 2 years but ill try that too
1991 240sx se
5 speed
injen cai
apexi n1 dual
Old 01-22-2003, 09:07 AM   #6
gregsr20
gregsr20's Avatar
gregsr20 is an unknown quantity at this point
try replacing the thermostat again, i had the same problem, i replaced the thermy first, hoses and eventually the radiator, on a hunch, i decided to check the thermostat again, and sure enough it was stuck
fast cars are dangerous, save lives drive HONDA'S
gregsr20 is offline   Reply With Quote
