Old 01-22-2003, 10:28 AM   #1
live2drift2live
live2drift2live is an unknown quantity at this point
Rewiring of Harness
I have been searching and been seeing a lot of notes of having to solder and rewire your SR harness. Is this tru? or just for cut lines? B/c if it is I was wondering where I can get a diagram so I can possibly make a plug and play system adaptor for the harness once i get my swap. Thanks alot
JBM
Goals in Life-
Get a 240SX- soon
Get Turbo-distant
Learn Japanese and go to Japan-Far far away in land of rising sun.
live2drift2live is offline   Reply With Quote
Old 01-22-2003, 11:36 AM   #2
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Buy a car, drive it around. Save some money then email me.
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 01-22-2003, 01:26 PM   #3
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
Check out www.heavythrottle.com , they have a diagram listed there that explains what needs to be connected to what... Also, it is possible to swimply disassemble the wiring connections and change the pin-outs. That's a better method that cutting and splicing.
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 01-22-2003, 11:11 PM   #4
TegGSR96
TegGSR96 is an unknown quantity at this point
is it a hard task to rewire it yourself? ive seen diagrams and stuff and it doesnt look too complicated, but ive heard a lot of people who've had many problems arise..
Alex
TegGSR96 is offline   Reply With Quote
Old 01-22-2003, 11:14 PM   #5
N1ceDrgn
N1ceDrgn's Avatar
It's not that bad.. do some research, figure out what the wires are for on each end of the harnesses you want to connect.. take your time, re-pin each connector that is supposed to connect, or if you're not that maticulous, take your time and splice them together.. just remember.. take your time and be patient, it's not that bad if you do..
Old 01-24-2003, 12:07 PM   #6
fast-datsun
fast-datsun is an unknown quantity at this point
solider all splices or some where down the road you WILL have electrical problem from loose but-connectors...
fast-datsun is offline   Reply With Quote
