![]() Join Date: Sep 2006
solid mounted exhaust question
only doing this because the greddy ti-c sits so dam low! its not the rubber mounts or car, it came shitty.
idea is to weld two thick steel tabs to pipe with gussets. bolt to rear subframe. i tacked on a tab and bolted it up. the exhaust was 3 inches higher with no-clearance problems. or take more time cut/bend existing hangers? no flex pipe. so that sucks too, any input ? |
![]() Join Date: Nov 2006
why not make the hangers shorter? that would be alot better. to me i think the exhaust needs no move some. so solid mounts wouldnt be the best.
92 vert converted 5speed and other little things |
![]() Join Date: Apr 2002
89 S13 hatch/////98 Subaru 2.5RS |
![]() Join Date: Nov 2004
Do it.
It'll be rock hard. Might as well. I mean if the exhaust is going to get hit, it'll get hit both ways. Mount it to the subframe and maybe one place further up. Done.
#6 | |
We did this on our shop car, only thing is if you go of track or over something in the road, the exhaust can't move to accomadate the obstruction, so you either break stuff or bend it. just make your hangers shorter and if you are going to solid mount, use a flex pipe or your shit will break somewhere.
![]() $pending dead pre$ident$ J@CK@TT@CK! |
![]() Join Date: Jan 2006
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
It will make a lot of noise and like stated above, if you hit something (you can't always see or avoid it) you will bend/break your exhaust or the mounts or what ever the mounts are mounted to.
Use shorter hangers with rubber mounts. |
AFC #1
![]() Join Date: Oct 2003
Just shorten the metal hangers and use Urethane bushings.
The car will be unbearable noisy. The welds with crack from the vibrations and with break when you hit something if you hard mount.
#10 | |
Before you go spending money making solid mounts or shortening them just try what I suggested. My exhaust sits maybe 1/2" lower than my frame rails.
![]() Join Date: Apr 2006
i bolted my megan exhaust to the body and the fucker started melting my carpet if i drive for more then an hour.
it smells yummy -los china fitment rocks
