Old 02-25-2008, 10:36 AM   #1
JTunedMotorsports
Zilvia.net GB Vendor
Trader Rating: (65)
JTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enoughJTunedMotorsports will become famous soon enough
Feedback Score: 65 reviews
Send a message via AIM to JTunedMotorsports
S13 wiper Intermittent stopped...will not work.need help
hello all
here is my situation...
my 91 240 has wiper intermittent problem...it works sometimes and then sometimes does not..
I recently finished a 90 240 and it worked for a couple weeks and now the intermittent does not work at all on that car either.
I have swaped wiper stalks cause I have a few around and that did not fix any of the probs...I checked fuses relays and have had no success...its seens from talking to a few customers that this is a common prob.
any one with expericnce please help me out
thanks
JIM
JTunedMotorsports is offline   Reply With Quote
Old 02-25-2008, 10:45 AM   #2
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
you should PM ProjectRDM. i had wiper problems and i was lurking around here for anything related to wipers and he chimed in every time with useful info.
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-25-2008, 01:59 PM   #3
JTunedMotorsports
Trader Rating: (65)
thank you i will look into pm.ing him
Old 02-25-2008, 02:32 PM   #4
projectRDM
projectRDM's Avatar
Swap the wiper amp, green box in the driver side corner of the engine compartment. That usually takes care of it, all 89-94 models use the same unit. If not, it's the motor, but I've only seen one dead/bad motor in thirteen years of fooling with these cars.
People will say it's a ground or wiring problem, ignore them. The wiper motor grounds through the chassis, the amp takes it's ground through the chassis harness inside. If that was the culprit you'd have nearly everything else electrical giving you problems.
FORMERLY R240NA
