Old 03-05-2008, 02:26 PM   #1
flawlessflo3190
flawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enough
!!!!fs: eclipe touch sreen gps video radio!!!!!!!
ok im selling my eclipe avn radio , it has dvd , video mode ( for cameras ) , navigation system , 50 watts amp build inside ( i think its 50 or 25 ) 2 cd inputs , fm and am .... its touch sreen ....the screen is 7'' and there is NO SCRATCHES ... it fits perfect in the s13 radio space .... it clears by like 1 ml ? its just perfect for s13 ....lol works great need to sell it to pay for my engine bay paint job.....oh i have all the wire harness also...... im asking $650 shipped.....
flawlessflo3190 is offline   Reply With Quote
Old 03-05-2008, 05:13 PM   #2
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
this is a dumb question but what is the display color?
ross.cottrill is offline   Reply With Quote
Old 03-05-2008, 05:39 PM   #3
S13Leprechaun
S13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant futureS13Leprechaun has a brilliant future
prolly blue or red.. lol...
what year eclipseis this out of? stock??
thurs. knights.
S13Leprechaun is offline   Reply With Quote
Old 03-05-2008, 08:54 PM   #5
ross.cottrill
ill give you $500 picked up im in oviedo lmk.....Ross
Old 03-06-2008, 06:58 PM   #6
flawlessflo3190
GENERAL
Power Supply:
13.2V DC (11-16V)
Current Drain: 3.5A (0.5W)
Power Output: 50 watts x 4 (MAX)
Lineout Output Level: 0.8V (0dB)
Dimensions (W x H x D): 7-1/2 inches x 4-1/2 inches x 6-1/2 (180 mm x 100 mm x 165 mm)
MASS (Weight): 3.7 kg
Display
Display:
6.5-inch wide (16:9), low-glare panel
Resolution: 280,800 dots
(400 x 234 x 3)
Display Method: Through-type color filter
Panel Type: Color TFT active matrix
Brightness: 150 (cd/m3)
Drive System: Horizontal-shaped
cathode tube
System: NTSC
Screen Aspect Ratio: 4 types
FM TUNER
Frequency Response:
30-15,000Hz, +/- 3dB
Stereo Separation: 38 dB (1 kHz)
CD SECTION
Frequency Response:
20-20,000Hz, +/- 1dB
Total Harmonic Distortion: 0.03 dB (0 dB, 1 kHz)
EQUALIZER SECTION
Graphic Equalizer:
63 Hz ~ 12,000 kHz (1/2 oct step) +/- 10 dB
The AVN2454 is not without its quirks. There is a video output from the unit to connect outboard monitors. This is a great feature. However, it only works when you’re playing a DVD or using the AV input. It does not display any picture in the DVD navigation mode. I realize that it’s not necessary for the other monitors to show the navigation, but it would take care of the kid’s question, “Are we there yet?”
Most external monitors have wireless headphone capability that requires a fixed output from the source. The AVN2454 does not have a fixed level output. The result is that you cannot listen to a DVD with the headphones without having the volume on the system at a high level.
Sound Q & Performance
I was a little surprised that Eclipse would offer a source unit with such low output voltage. However, the AVN2454’s sound quality was more than acceptable. The equalizer was easy to use and offered enough bands to fix any small problems you might experience in your system setup.
The picture quality was superb — DVD’s looked great.
The real reason you buy this unit is for its navigation features. For this purpose, the AVN2454 is fantastic. I was able to plot a trip from Cincinnati, Ohio, to Sacramento, California, in less than three seconds. Even better, The AVN2454 offered three different routes based on travel time and ease of route. I tried several times to trick the navigation by veering off route. Each time, the AVN2454 rerouted me quickly. The only complaint I had about the navigation was that the voice prompt was a little too soft on the volume. It might have worked better if it muted the entire stereo instead of only one channel.
Summary
Overall, the AVN2454 is a real winner. It does a great job of combining a ton of features into a double-DIN chassis. Its ease of use and superb navigation makes the AVN2454 a great “all-in-one” choice. The AVN2454 is the perfect solution for someone who gets lost or lives with someone who does. Either way, the AVN2454 will not only get you there, it will get you there in style.
Old 03-06-2008, 07:52 PM   #7
flawlessflo3190
(ill give you $500 picked up im in oviedo lmk.....Ross)
ok just call me so that we can meet somewhere tomorrow 407 924 9787
Old 03-06-2008, 10:51 PM   #8
CAPTAINNEO
CAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond reputeCAPTAINNEO has a reputation beyond repute
Send a message via AIM to CAPTAINNEO
i think he meant that it's an Eclipse head unit. not mitsubishi eclipse. eclipse. the audio brand.
good luck with sale.
CAPTAINNEO is offline   Reply With Quote
Old 03-07-2008, 06:42 PM   #9
flawlessflo3190
yea thanks for exlaining captainneo...
Old 03-09-2008, 09:10 PM   #10
flawlessflo3190
bump some one buy .... i know u want it
Old 03-10-2008, 12:17 AM   #11
lostmenoggin
lostmenoggin is a jewel in the roughlostmenoggin is a jewel in the roughlostmenoggin is a jewel in the roughlostmenoggin is a jewel in the roughlostmenoggin is a jewel in the roughlostmenoggin is a jewel in the roughlostmenoggin is a jewel in the rough
any pics of it installed in a 240?
lostmenoggin is offline   Reply With Quote
Old 03-10-2008, 05:00 PM   #12
flawlessflo3190
here it is on a s14 i saw
http://images.google.com/imgres?imgu...3Doff%26sa%3DX
vbrep_register("1878681")
Old 03-10-2008, 11:04 PM   #13
OfourTHREEfive
OfourTHREEfive is making a name for him/her selfOfourTHREEfive is making a name for him/her self
Any trades? Wheels nitrous kit, or SAFC2?
OfourTHREEfive is offline   Reply With Quote
Old 03-11-2008, 05:35 AM   #14
flawlessflo3190
i need a wideband , safc1 & 2 , aluminum rad , bov , intercooler piping ....
Old 03-11-2008, 05:36 AM   #15
flawlessflo3190
pics on the wheels? lmk and do u got safc1 and 2 ?lmk
Old 03-11-2008, 08:11 PM   #16
ross.cottrill
sorry man ive been busy,ill call ya 2moro!
Old 03-11-2008, 08:21 PM   #17
MrSkinny
MrSkinny is an unknown quantity at this point
i already sent payment for this thing...
MrSkinny is offline   Reply With Quote
Old 03-12-2008, 07:23 PM   #18
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
^ If not, I got an S14 Koyo and a SAFC and I'm in Tampa
burgy240 is offline   Reply With Quote
Old 03-12-2008, 07:55 PM   #19
flawlessflo3190
sold!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-12-2008, 09:31 PM   #20
MrSkinny
can u confirm that you recevied payment and the item is shipped?
Old 03-12-2008, 09:40 PM   #21
flawlessflo3190
yes i sent it out im in the process of sending tracking number...thanks for your bussiness......please close thread
