Z32 maf, researched already but need quick clarification *
i have been doing a lot of research and searching but i still need help to clear this up
from the diagrams i read it does note seem and my z32 maf was previously wired correctly the more i look at it the more i believe that my white and orange wire need to be separated for proper install So my wires are (R-L); open, black w/white stripe, orange, black, white, open and currently the B and D wires are connected. if possible help me figure this out so i can wire my maf, thx ![]() ![]() support web addresses; http://www.az240sx.org/tech/mafs/z32diagram-correct.jpg http://jimwolftechnology.com/wolfpdf...%20NISSANS.PDF http://www.zilvia.net/f/showthread.php?p=886276 http://www.srswap.com/ http://www.zeroyon.com/index/content/view/28/47/1/1/ some one correct me if i am wrong; the orange (D) MUST be disconnected from (B) and grounded w/harness. thats the same conclusion I've come to but need a second, some one second my conclusion :yes: Wiring Chart for those with stock Z32 connector: Z32 MAF Pin - SR20DET Stock Engine Harness Pin B - White Wire (MAF Signal) Pin C - Chassis Ground (Connect this to any ground on the chassis) Pin D - Black Wire (Harness Ground) Pin E - Black/White Wire (Power) |
thx man
oh does it matter that they say its a j30 sensor? |
#5 | |
from the research i am told to split B and D, white and organge but on other forms some are saying to leave the wiring as is becuase the one will connect directly to the harness ground and all will be ok just need a second opinion ??? SPLICE white and orange...... Or leave them connected??? |
![]() Join Date: Dec 2007
Trader Rating: (25)
![]() Feedback Score: 25 reviews
If you have the time and to avoid cutting and splicing, just re-pin the pigtails. Take your SR pigtail and disconnect the pins(white, black,black/white) and disconnect the pins from the Z32 pigtail and write down which letter each wire was associated with on your Z32 pigtail and reconnect your SR wires into the Z32 pigtail and you have a clean install.
