![]() Join Date: Feb 2006
Running fine then cuts off, no restart. SR
The issue. I installed Sard 850cc injectors a few days ago. Car ran fine.
Today I installed my 264 cams and the car ran and drove fine. Then I installed new plugs and pop filter and it was, again, running fine. I had it idling for about 15 -20 min in the driveway and it starts to run slightly rough(the average person wouldn't be able to hear the difference it was so slight) then it cuts off. I tried to crank it and turned but no start. Checked all fuses, pulled plugs for injectors, turned it so I know its not flooding. Im very confused as to what it could be. It sounds like its getting no spark because when you crank it turns over smoothly like when you take out your spark plugs and coil packs to clear a flooded engine of gas. Just a little more info: SR20DET Car is ROM tuned for 272 cams, 740cc injectors. I did 15% correction on my SAFC to compensate for the 850cc injectors. Thanks for any help. OB ![]() |
![]() Join Date: Nov 2007
could part of the problem be that you have 264 cams installed and the ROM is tuned for 272? also, was this a cold start or a warm start?
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
Well I drove the car for several days on stock cams, same tune. I just drove the car today on the 264's fine, came back and idled for 15-20 min.s. It died by itself and wont start. It also cranks really wierd as I was describing. Really smooth if that makes any sense.
Obee...Did you try jumping the car? maybe bad batt/alt have you had these checked? do the basics first, may be in the tune??? but if it ran fine before on the same tune then start from jump.
so it was all fine and it seems like there is no compression. that's weird, are you cylinders filled with gas? bad rings? never heard of this before. i'll get back to you
